Errore durante caricamento bootloader ATMEL328
Salve,
sto provando a caricare il bootloader di arduino su di un chip vergine seguendo questa guida con la IDE 1.6.5 e ottenendo il seguente errore:
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Errore durante la scrittura del bootloader
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x1e9514
avrdude: Expected signature for ATmega328P is 1E 95 0F
         Double check chip, or use -F to override this check.
avrdude done.  Thank you.
Sapreste darmi qualche dritta?
C'è differenza tra un Atmega328p-pu è un atmega328-pu?
Inizio a rispondermi da solo e per gli altri.
La versione montata da Arduino rev3 è la 328P-PU. La P sta per PicoPower ovvero per il risparmio di corrente (solo se si attivano dei settaggi e accorgimenti da codice).
Inoltre hanno un identificativo diverso tale che l'IDE non lo riconosce.
Per farlo riconoscere bisogna modificare due file : boards.txt e avrdude.conf aggiungendo il nuovo dispositivo.
Ora non mi è ancora chiaro come farlo... È tardi ... Domani li apro e capisco. Forse...
Quello che però mi sta facendo veramente inc...re e che ne ho comprato 3 da RS tutti 328-PU quando erano disponibili i 328P-PU. La differenza era di circa 0.30€ ciascuno... Sicuramente mi sono fatto fregare dal prezzo... Il risparmio non è mai guadagno. Magia a me ... Tutta la serata a imprecare ...
Scusate lo sfogo.
inter1908:
Come hai giá scoperto hanno dei identificatori diversi e percui non funziona. Il controller selezionalto per fare un caricamento ICSP deve corrispondere a quello collegato al programmatore.
Riguarda la scelta del componente nello shop é compito Tuo informarti delle possibilitá e differenze.
Ciao Uwe
uwefed:
Ciao Uwe
È' chiaro che è una mia responsabilità. Mai avrei pensato ad un problema simile.
Potresti confermarmi (ove tu ne fossi a conoscenza) che la modifica dei due file risolve il problema? Inoltre che tu sappia la differenza è solo sul 'consumo'? O mi devo aspettare altro?
Ciao a tutti,
ho risolto il problema di caricamento del bootloader sul chip ATMEL328-PU (che è diverso dal ATMEL328P-PU) . La guida/procedimento da seguire è questa. In rete ce ne sono diversa ma alla fine sono tutte uguali.
La IDE utilizzata è la 1.6.5 .
Ho dovuto aggiungere le seguenti righe nel file boards.txt
atmega328pu.name=Atmega328PU
atmega328pu.bootloader.tool=avrdude
atmega328pu.upload.protocol=stk500
atmega328pu.upload.maximum_size=32256
atmega328pu.upload.speed=115200
atmega328pu.bootloader.low_fuses=0xff
atmega328pu.bootloader.high_fuses=0xde
atmega328pu.bootloader.extended_fuses=0x05
atmega328pu.bootloader.path=optiboot
atmega328pu.bootloader.file=optiboot/optiboot_atmega328.hex
atmega328pu.bootloader.unlock_bits=0x3F
atmega328pu.bootloader.lock_bits=0x0F
atmega328pu.build.mcu=atmega328pu
atmega328pu.build.f_cpu=16000000L
atmega328pu.build.core=arduino
Ho dovuto aggiungere le seguenti righe nel file avrdude.conf
# ATmega328-PU
part
 id = "m328pu";
 desc = "ATMEGA328PU";
 has_debugwire = yes;
 flash_instr = 0xB6, 0x01, 0x11;
 eeprom_instr  = 0xBD, 0xF2, 0xBD, 0xE1, 0xBB, 0xCF, 0xB4, 0x00,
 0xBE, 0x01, 0xB6, 0x01, 0xBC, 0x00, 0xBB, 0xBF,
 0x99, 0xF9, 0xBB, 0xAF;
 stk500_devcode  = 0x86;
 # avr910_devcode = 0x;
 signature       = 0x1e 0x95 0x14;
 pagel           = 0xd7;
 bs2             = 0xc2;
 chip_erase_delay = 9000;
    pgm_enable = "1 0 1 0 1 1 0 0 0 1 0 1 0 0 1 1",
		 "x x x x x x x x x x x x x x x x";
    chip_erase = "1 0 1 0 1 1 0 0 1 0 0 x x x x x",
    timeout	= 200;
    stabdelay	= 100;
    cmdexedelay	= 25;
    synchloops	= 32;
    bytedelay	= 0;
    pollindex	= 3;
    pollvalue	= 0x53;
    predelay	= 1;
    postdelay	= 1;
    pollmethod	= 1;
    pp_controlstack =
	0x0E, 0x1E, 0x0F, 0x1F, 0x2E, 0x3E, 0x2F, 0x3F,
	0x4E, 0x5E, 0x4F, 0x5F, 0x6E, 0x7E, 0x6F, 0x7F,
	0x66, 0x76, 0x67, 0x77, 0x6A, 0x7A, 0x6B, 0x7B,
	0xBE, 0xFD, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00;
    hventerstabdelay	= 100;
    progmodedelay	= 0;
    latchcycles		= 5;
    togglevtg		= 1;
    poweroffdelay	= 15;
    resetdelayms	= 1;
    resetdelayus	= 0;
    hvleavestabdelay	= 15;
    resetdelay		= 15;
    chiperasepulsewidth	= 0;
    chiperasepolltimeout = 10;
    programfusepulsewidth = 0;
    programfusepolltimeout = 5;
    programlockpulsewidth = 0;
    programlockpolltimeout = 5;
    ocdrev              = 1;
    memory "eeprom"
	paged		= no;
	page_size	= 4;
	size		= 1024;
	min_write_delay = 3600;
	max_write_delay = 3600;
	readback_p1	= 0xff;
	readback_p2	= 0xff;
	read = " 1 0 1 0 0 0 0 0",
	       " 0 0 0 x x x a9 a8",
	       " a7 a6 a5 a4 a3 a2 a1 a0",
	       " o o o o o o o o";
	write = " 1 1 0 0 0 0 0 0",
		" i i i i i i i i";
	loadpage_lo = " 1 1 0 0 0 0 0 1",
		      " 0 0 0 0 0 0 0 0",
		      " 0 0 0 0 0 0 a1 a0",
		      " i i i i i i i i";
	writepage = " 1 1 0 0 0 0 1 0",
		    " 0 0 x x x x a9 a8",
		    " a7 a6 a5 a4 a3 a2 0 0",
		    " x x x x x x x x";
	mode		= 0x41;
	delay		= 20;
	blocksize	= 4;
	readsize	= 256;
    memory "flash"
	paged		= yes;
	size		= 32768;
	page_size	= 128;
	num_pages	= 256;
	min_write_delay = 4500;
	max_write_delay = 4500;
	readback_p1	= 0xff;
	readback_p2	= 0xff;
	read_lo = " 0 0 1 0 0 0 0 0",
		  " 0 0 a13 a12 a11 a10 a9 a8",
		  " o o o o o o o o";
	read_hi = " 0 0 1 0 1 0 0 0",
		  " o o o o o o o o";
	loadpage_lo = " 0 1 0 0 0 0 0 0",
		      " 0 0 0 x x x x x",
		      " x x a5 a4 a3 a2 a1 a0",
		      " i i i i i i i i";
	loadpage_hi = " 0 1 0 0 1 0 0 0",
		      " 0 0 0 x x x x x",
		      " i i i i i i i i";
	writepage = " 0 1 0 0 1 1 0 0",
		    " a7 a6 x x x x x x",
		    " x x x x x x x x";
	mode		= 0x41;
	delay		= 6;
	blocksize	= 128;
	readsize	= 256;
    memory "lfuse"
	size = 1;
	read = "0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0",
	       "x x x x x x x x o o o o o o o o";
	write = "1 0 1 0 1 1 0 0 1 0 1 0 0 0 0 0",
	      	"x x x x x x x x i i i i i i i i";
    memory "hfuse"
	size = 1;
	read = "0 1 0 1 1 0 0 0 0 0 0 0 1 0 0 0",
	write = "1 0 1 0 1 1 0 0 1 0 1 0 1 0 0 0",
    memory "efuse"
	size = 1;
	read = "0 1 0 1 0 0 0 0 0 0 0 0 1 0 0 0",
	       "x x x x x x x x x x x x x o o o";
	write = "1 0 1 0 1 1 0 0 1 0 1 0 0 1 0 0",
	      	"x x x x x x x x x x x x x i i i";
    memory "lock"
	size = 1;
	read = "0 1 0 1 1 0 0 0 0 0 0 0 0 0 0 0",
	       "x x x x x x x x x x o o o o o o";
	write = "1 0 1 0 1 1 0 0 1 1 1 x x x x x",
	      	"x x x x x x x x 1 1 i i i i i i";
    memory "calibration"
	size = 1;
	read = "0 0 1 1 1 0 0 0 0 0 0 x x x x x",
	       "0 0 0 0 0 0 0 0 o o o o o o o o";
    memory "signature"
	size = 3;
	read = "0 0 1 1 0 0 0 0 0 0 0 x x x x x",
	       "x x x x x x a1 a0 o o o o o o o o";
Ovviamente, quando si sceglie la scheda va selezionato Atmega328PU
Spero di aver fatto cosa gradita,
A.
