Errore durante l'apertura della porta seriale
Ragazzi ho un problema che mi sta scoppiando la testa, stavo compilando tranquillamente... e improvvisamente mi appare sto errore:
Errore durante lapertura della porta seriale {0}
avrdude: usbdev_open(): did not find any USB device "usb"
processing.app.SerialException: Errore durante lapertura della porta seriale '{0}'.
	at processing.app.Serial.<init>(Serial.java:178)
	at processing.app.Serial.<init>(Serial.java:92)
	at processing.app.SerialMonitor.openSerialPort(SerialMonitor.java:207)
	at processing.app.Editor.handleSerial(Editor.java:2481)
	at processing.app.Editor$17.actionPerformed(Editor.java:665)
	at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
	at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
	at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
	at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
	at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
	at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833)
	at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877)
	at java.awt.Component.processMouseEvent(Component.java:6505)
	at javax.swing.JComponent.processMouseEvent(JComponent.java:3312)
	at java.awt.Component.processEvent(Component.java:6270)
	at java.awt.Container.processEvent(Container.java:2229)
	at java.awt.Component.dispatchEventImpl(Component.java:4861)
	at java.awt.Container.dispatchEventImpl(Container.java:2287)
	at java.awt.Component.dispatchEvent(Component.java:4687)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
	at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
	at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
	at java.awt.Container.dispatchEventImpl(Container.java:2273)
	at java.awt.Window.dispatchEventImpl(Window.java:2719)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:729)
	at java.awt.EventQueue.access$200(EventQueue.java:103)
	at java.awt.EventQueue$3.run(EventQueue.java:688)
	at java.awt.EventQueue$3.run(EventQueue.java:686)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
	at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
	at java.awt.EventQueue$4.run(EventQueue.java:702)
	at java.awt.EventQueue$4.run(EventQueue.java:700)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:699)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
	at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
Caused by: gnu.io.UnsupportedCommOperationException: Invalid Parameter
	at gnu.io.RXTXPort.setSerialPortParams(RXTXPort.java:213)
	at processing.app.Serial.<init>(Serial.java:163)
	... 42 more
Uso linux, precisamente Lubuntu 13.04, prima andava tutto tranquillamente, non capisco cosa sia successo!
"prima" di quando? cos'hai fatto perché ti venisse fuori questo problema?
Che IDE usi? Da dove l'hai installato?
Uso l'IDE 1.0.4, non ho fatto assolutamente nulla prima che mi venisse fuori questo problema, ora ho risolto avviando il programma come root
da terminale
sudo arduino
e non mi da più questo errore, boh!!
Allora è solo una questione di permessi. Leggi in fondo qui:
http://playground.arduino.cc//Linux/Ubuntu
if you use the USB port to dialog, you should add yourself to the group 'dialout' in order to have write permissions on that port:
sudo usermod -aG dialout <myuser>
PS:
MAI, dico MAI avviare un normale programma come root. Come root ti devi collegare solo per fare manutenzione e basta.
