Errore ESP8266 wifi-loop
#include <ThingSpeak.h>
#include <WiFiManager.h>
#include "DHT.h"
#define DHTPIN 14
#define DHTTYPE DHT11
#define TRIGGER_PIN 10
#define ctra 4
#define ctrb 20
#define ctrc 19
unsigned long myChannelNumber = 1729841;
const char * myWriteAPIKey = "xxxxxxxxxxxxxxxxxxxxx";
DHT dht(DHTPIN, DHTTYPE);
const float S_analog = 1023.0;
int co, nh3;
float no2;
  WiFi.mode(WIFI_STA);
  WiFiManager wm;
  pinMode(TRIGGER_PIN, INPUT);
  bool res;
  res = wm.autoConnect("beppeparini.in", "salubrita");
  pinMode(ctra, OUTPUT);
  pinMode(ctrb, OUTPUT);
  pinMode(ctrc, OUTPUT);
  dht.begin();
  if (!res) {
    Serial.println("Failed to connect");
    // ESP.restart();
  else {
    //if you get here you have connected to the WiFi
    Serial.println("connected...yeey :)");
  //checkButton();
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  digitalWrite(ctra, LOW);
  digitalWrite(ctrb, LOW);
  digitalWrite(ctrc, LOW);
  int MQ135 = analogRead(A0);
  delay(5000);
  digitalWrite(ctrc, HIGH);
  int MQ138  = analogRead(A0);
  delay(5000);
  digitalWrite(ctrb, HIGH);
  co = map (analogRead(A0), 0, S_analog, 1, 1000);
  delay(5000);
  nh3 = map (analogRead(A0), 0, S_analog, 1, 500);
  delay(5000);
  digitalWrite(ctra, HIGH);
  no2 = (map (lettura, 0, S_analog, 5, 1000)) / 100.0 ;
  delay(5000);
  Serial.println(t);
  Serial.println(h);
  Serial.println(MQ135);
  Serial.println(MQ138);
  Serial.println(co);
  Serial.println(nh3);
  Serial.println(no2);
  ThingSpeak.setField(1, t);
  ThingSpeak.setField(2, h);
  ThingSpeak.setField(3, MQ135);
  ThingSpeak.setField(4, MQ138);
  ThingSpeak.setField(5, co);
  ThingSpeak.setField(6, nh3);
  ThingSpeak.setField(7, no2);
  ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey);
  delay(30000);
  void checkButton(){
  if ( digitalRead(TRIGGER_PIN) == LOW ) {
     delay(50);
    if( digitalRead(TRIGGER_PIN) == LOW ){
      Serial.println("Button Pressed");
      // still holding button for 3000 ms, reset settings, code not ideaa for production
      delay(3000); // reset delay hold
        Serial.println("Button Held");
        Serial.println("Erasing Config, restarting");
        wm.resetSettings();
        ESP.restart();
      // start portal w delay
      Serial.println("Starting config portal");
      wm.setConfigPortalTimeout(120);
      if (!wm.startConfigPortal("beppeparini.in","salubrita")) {
        Serial.println("failed to connect or hit timeout");
        delay(3000);
        // ESP.restart();
Buonpomeriggio,
ho un problema con questo codice.
Viene compilato e caricato.
la scheda in questione è un nodemcu v3.
qui sotto l'errore che mi da in seriale:
load 0x4010f000, len 3460, room 16 tail 4 chksum 0xcc load 0x3fff20b8, len 40, room 4 tail 4 chksum 0xc9 csum 0xc9 v00058260
:warning:
Ti segnalo che, nella sezione in lingua Inglese, si può scrivere SOLO in Inglese ... quindi, per favore, la prossima volta presta più attenzione in quale sezione metti i tuoi post; questa volta esso è stato spostato, da un moderatore della sezione di lingua Inglese, nella sezione di lingua Italiana ... la prossima volta potrebbe venire direttamente eliminato. Grazie.
A quanto già detto da UKHeliBob, aggiungo che ...
... essendo il tuo primo post, nel rispetto del regolamento della sezione Italiana del forum (… punto 13, primo capoverso), ti chiedo cortesemente di presentarti IN QUESTO THREAD (spiegando bene quali conoscenze hai di elettronica e di programmazione ... possibilmente evitando di scrivere solo una riga di saluto) e di leggere con molta attenzione tutto il succitato REGOLAMENTO ... Grazie.
Guglielmo
P.S.: Ti ricordo che, purtroppo, fino a quando non sarà fatta la presentazione nell’apposito thread, nel rispetto del suddetto regolamento nessuno ti risponderà (eventuali risposte verrebbero temporaneamente nascoste), quindi ti consiglio di farla al più presto. :wink:
P.P.S.: MAI mettere in chiaro le proprie API Key ... ho corretto il tuo codice per eliminarla.
L'API Key era vecchia. Comunque ti ringrazio per il tuo aiuto!
... quello NON mi sembra un errore ma informazioni sul caricamento ... ti da solo quello o poi prosegue con altre info?
Guglielmo
Va in loop. si connette alla rete data, si disconnette per poi ricominciare da capo...
non vorrei che sia un problema/conflitto con la libreria wifimanager...
No è in loop
Si, ho capito, ma non ho idea allora del perché, mi spiace ... :roll_eyes:
Guglielmo
Grazie comunque
