errore TimeAlarmExample.pde
Salve ragazzi, sono nuovo di questo sito e un novellino per quanto riguarda Arduino,
come primo progetto volevo creare una classica sveglia, ma il problema sorge quando uso la libreria TimeAlarmExample.pde
mi restituisce errore:
In file included from /Users/Prodediego/Documents/Arduino/libraries/TimeAlarms/TimeAlarms.cpp:25:
/Users/Prodediego/Documents/Arduino/libraries/TimeAlarms/WProgram.h:7:20: error: wiring.h: No such file or directory
/Users/Prodediego/Documents/Arduino/libraries/TimeAlarms/TimeAlarms.cpp: In member function 'void TimeAlarmsClass::delay(long unsigned int)':
/Users/Prodediego/Documents/Arduino/libraries/TimeAlarms/TimeAlarms.cpp:256: error: 'millis' was not declared in this scope
Il codice in questione e' questo
* TimeAlarmExample.pde
 * This example calls alarm functions at 8:30 am and at 5:45 pm (17:45)
 * and simulates turning lights on at night and off in the morning
 * A weekly timer is set for Saturdays at 8:30:30
 * A timer is called every 15 seconds
 * Another timer is called once only after 10 seconds
 * At startup the time is set to Jan 1 2011  8:29 am
#include <Time.h>
#include <TimeAlarms.h>
  setTime(8,29,0,1,1,11); // set time to Saturday 8:29:00am Jan 1 2011
  // create the alarms
  Alarm.alarmRepeat(8,30,0, MorningAlarm);  // 8:30am every day
  Alarm.alarmRepeat(17,45,0,EveningAlarm);  // 5:45pm every day
  Alarm.alarmRepeat(dowSaturday,8,30,30,WeeklyAlarm);  // 8:30:30 every Saturday
  Alarm.timerRepeat(15, Repeats);            // timer for every 15 seconds
  Alarm.timerOnce(10, OnceOnly);             // called once after 10 seconds
void  loop(){
  digitalClockDisplay();
  Alarm.delay(1000); // wait one second between clock display
// functions to be called when an alarm triggers:
void MorningAlarm(){
  Serial.println("Alarm: - turn lights off");
void EveningAlarm(){
  Serial.println("Alarm: - turn lights on");
void WeeklyAlarm(){
  Serial.println("Alarm: - its Monday Morning");
void ExplicitAlarm(){
  Serial.println("Alarm: - this triggers only at the given date and time");
void Repeats(){
  Serial.println("15 second timer");
void OnceOnly(){
  Serial.println("This timer only triggers once");
void digitalClockDisplay()
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
void printDigits(int digits)
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
wiring.h non esiste piú nella versione IDE1.0. adesso si chiama arduino.h
Ciao Uwe
si ma nel codice non c'e' wring.h e' questo il problema!
Scusami:
metti nella libreria TimeAlarms.h
al posto di "WProgram.h" "Arduino.h"
oppure compila con IDE 0023, la versione precedente del IDE.
http://arduino.cc/en/Main/ReleaseNotes:
The WProgram.h file, which provides declarations for the Arduino API,
has been renamed to Arduino.h. To create a library that will work in
both Arduino 0022 and Arduino 1.0, you can use an #ifdef that checks
for the ARDUINO constant, which was 22 and is now 100. For example:
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
Ciao Uwe
