Errori di compilazione Wire.cpp twi_init was not declared in this scope
Salve a tutti,
sto provando a caricare su Arduino Mega 2560 v3 (a cui ho collegato lo schermo "Adafruit 2.8" TFT Touch Shield v2 Capacitive") uno sketch di prova del touch screen, ma rilevo una serie di errori in fase di compilazione.
Gli errori:
Arduino:1.6.6 (Mac OS X), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp: In member function 'void TwoWire::begin()':
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp:62:12: error: 'twi_init' was not declared in this scope
   twi_init();
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp: In member function 'void TwoWire::begin(uint8_t)':
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp:67:25: error: 'twi_setAddress' was not declared in this scope
   twi_setAddress(address);
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp:68:42: error: 'twi_attachSlaveTxEvent' was not declared in this scope
   twi_attachSlaveTxEvent(onRequestService);
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp:69:42: error: 'twi_attachSlaveRxEvent' was not declared in this scope
   twi_attachSlaveRxEvent(onReceiveService);
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp: In member function 'void TwoWire::end()':
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp:80:15: error: 'twi_disable' was not declared in this scope
   twi_disable();
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp: In member function 'uint8_t TwoWire::requestFrom(uint8_t, uint8_t, uint32_t, uint8_t, uint8_t)':
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp:113:68: error: 'twi_readFrom' was not declared in this scope
   uint8_t read = twi_readFrom(address, rxBuffer, quantity, sendStop);
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp: In member function 'uint8_t TwoWire::endTransmission(uint8_t)':
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp:172:76: error: 'twi_writeTo' was not declared in this scope
   int8_t ret = twi_writeTo(txAddress, txBuffer, txBufferLength, 1, sendStop);
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp: In member function 'virtual size_t TwoWire::write(uint8_t)':
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp:209:26: error: 'twi_transmit' was not declared in this scope
     twi_transmit(&data, 1);
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp: In member function 'virtual size_t TwoWire::write(const uint8_t*, size_t)':
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp:227:32: error: 'twi_transmit' was not declared in this scope
     twi_transmit(data, quantity);
exit status 1
Errore durante la compilazione
  Questo report potrebbe essere più ricco di informazioni con
  "Mostra un output dettagliato durante la compilazione"
  abilitato in "File > Impostazioni"
Lo sketch è questo:
  This is our touchscreen painting example for the Adafruit ILI9341
  captouch shield
  ----> http://www.adafruit.com/products/1947
  Check out the links above for our tutorials and wiring diagrams
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
#include <Adafruit_GFX.h>    // Core graphics library
#include <SPI.h>       // this is needed for display
#include <Adafruit_ILI9341.h>
#include <Wire.h>      // this is needed for FT6206
#include <Adafruit_FT6206.h>
// The FT6206 uses hardware I2C (SCL/SDA)
Adafruit_FT6206 ctp = Adafruit_FT6206();
// The display also uses hardware SPI, plus #9 & #10
#define TFT_CS 10
#define TFT_DC 9
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// Size of the color selection boxes and the paintbrush size
#define BOXSIZE 40
#define PENRADIUS 3
int oldcolor, currentcolor;
void setup(void) {
  while (!Serial);     // used for leonardo debugging
  Serial.println(F("Cap Touch Paint!"));
  tft.begin();
  if (! ctp.begin(40)) {  // pass in 'sensitivity' coefficient
    Serial.println("Couldn't start FT6206 touchscreen controller");
    while (1);
  Serial.println("Capacitive touchscreen started");
  tft.fillScreen(ILI9341_BLACK);
  // make the color selection boxes
  tft.fillRect(0, 0, BOXSIZE, BOXSIZE, ILI9341_RED);
  tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, ILI9341_YELLOW);
  tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, ILI9341_GREEN);
  tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, ILI9341_CYAN);
  tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, ILI9341_BLUE);
  tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, ILI9341_MAGENTA);
  // select the current color 'red'
  tft.drawRect(0, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
  currentcolor = ILI9341_RED;
  // Wait for a touch
  if (! ctp.touched()) {
    return;
  // Retrieve a point
  TS_Point p = ctp.getPoint();
  // Print out raw data from screen touch controller
  Serial.print("X = "); Serial.print(p.x);
  Serial.print("\tY = "); Serial.print(p.y);
  Serial.print(" -> ");
  // flip it around to match the screen.
  p.x = map(p.x, 0, 240, 240, 0);
  p.y = map(p.y, 0, 320, 320, 0);
  // Print out the remapped (rotated) coordinates
  Serial.print("("); Serial.print(p.x);
  Serial.print(", "); Serial.print(p.y);
  Serial.println(")");
  if (p.y < BOXSIZE) {
     oldcolor = currentcolor;
     if (p.x < BOXSIZE) {
     } else if (p.x < BOXSIZE*2) {
       currentcolor = ILI9341_YELLOW;
       tft.drawRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
     } else if (p.x < BOXSIZE*3) {
       currentcolor = ILI9341_GREEN;
       tft.drawRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
     } else if (p.x < BOXSIZE*4) {
       currentcolor = ILI9341_CYAN;
       tft.drawRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
     } else if (p.x < BOXSIZE*5) {
       currentcolor = ILI9341_BLUE;
       tft.drawRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
     } else if (p.x <= BOXSIZE*6) {
       currentcolor = ILI9341_MAGENTA;
       tft.drawRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
     if (oldcolor != currentcolor) {
        if (oldcolor == ILI9341_RED)
        if (oldcolor == ILI9341_YELLOW)
        if (oldcolor == ILI9341_GREEN)
        if (oldcolor == ILI9341_CYAN)
        if (oldcolor == ILI9341_BLUE)
        if (oldcolor == ILI9341_MAGENTA)
  if (((p.y-PENRADIUS) > BOXSIZE) && ((p.y+PENRADIUS) < tft.height())) {
    tft.fillCircle(p.x, p.y, PENRADIUS, currentcolor);
Avete idea di quale potrebbe essere il problema?
Grazie :slight_smile:
Con la versione 1.6.5 dell'IDE funziona...
