I haven't been able to compile my sketch for my arduino uno, I had replaced a bad one and thought my issues were over, but I guess not. is there something wrong with my code?
here is the code:
#include <SoftwareSerial.h>
#include <TinyGPS.h>
#include <Blynk.h>
#include <Adafruit_HMC5883_U.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
char auth[] = "blynk-token";
#define GPS_TX_PIN 6
#define BLUETOOTH_TX_PIN 10
#define BLUETOOTH_RX_PIN 11
#define MOTOR_A_EN_PIN 4
#define MOTOR_B_EN_PIN 5
#define MOTOR_A_IN_1_PIN 2
#define MOTOR_A_IN_2_PIN 3
#define MOTOR_B_IN_1_PIN 12
#define MOTOR_B_IN_2_PIN 13
// If one motor tends to spin faster than the other, add offset
#define MOTOR_A_OFFSET 20
#define MOTOR_B_OFFSET 0
// You must then add your 'Declination Angle' to the compass, which is the 'Error' of the magnetic field in your location.
// Find yours here: http://www.magnetic-declination.com/
// Mine is: 13° 24' E (Positive), which is ~13 Degrees, or (which we need) 0.23 radians
#define DECLINATION_ANGLE 0.21f
// The offset of the mounting position to true north
// It would be best to run the /examples/magsensor sketch and compare to the compass on your smartphone
#define COMPASS_OFFSET 0.0f
// How often the GPS should update in MS
// Keep this above 1000
#define GPS_UPDATE_INTERVAL 1000
// Number of changes in movement to timeout for GPS streaming
// Keeps the cooler from driving away if there is a problem
#define GPS_STREAM_TIMEOUT 18
// Number of changes in movement to timeout for GPS waypoints
#define GPS_WAYPOINT_TIMEOUT 45
// Definitions (don't edit these)
struct GeoLoc {
float lat;
float lon;
// GPS
TinyGPS gps;
// Master Enable
bool enabled = false;
//WidgetTerminal terminal(V3);
// Serial components
SoftwareSerial bluetoothSerial(BLUETOOTH_TX_PIN, BLUETOOTH_RX_PIN);
SoftwareSerial nss(GPS_TX_PIN, 255); // TXD to digital pin 6
/* Compass */
Adafruit_HMC5883_Unified mag = Adafruit_HMC5883_Unified(12345);
GeoLoc checkGPS() {
Serial.println("Reading onboard GPS: ");
bool newdata = false;
unsigned long start = millis();
while (millis() - start < GPS_UPDATE_INTERVAL) {
if (feedgps())
newdata = true;
if (newdata) {
return gpsdump(gps);
GeoLoc coolerLoc;
coolerLoc.lat = 0.0;
coolerLoc.lon = 0.0;
return coolerLoc;
// Get and process GPS data
GeoLoc gpsdump(TinyGPS &gps) {
float flat, flon;
unsigned long age;
gps.f_get_position(&flat, &flon, &age);
GeoLoc coolerLoc;
coolerLoc.lat = flat;
coolerLoc.lon = flon;
Serial.print(coolerLoc.lat, 7); Serial.print(", "); Serial.println(coolerLoc.lon, 7);
return coolerLoc;
// Feed data as it becomes available
bool feedgps() {
while (nss.available()) {
if (gps.encode(nss.read()))
return true;
return false;
// Killswitch Hook
BLYNK_WRITE(V1) {
enabled = !enabled;
//Stop the wheels
stop();
// GPS Streaming Hook
BLYNK_WRITE(V2) {
Serial.println("Received remote GPS: ");
// Print 7 decimal places for Lat
Serial.print(gps.getLat(), 7); Serial.print(", "); Serial.println(gps.getLon(), 7);
GeoLoc phoneLoc;
phoneLoc.lat = gps.getLat();
phoneLoc.lon = gps.getLon();
driveTo(phoneLoc, GPS_STREAM_TIMEOUT);
// Terminal Hook
BLYNK_WRITE(V3) {
Serial.print("Received Text: ");
Serial.println(param.asStr());
String rawInput(param.asStr());
int colonIndex;
int commaIndex;
do {
commaIndex = rawInput.indexOf(',');
colonIndex = rawInput.indexOf(':');
if (commaIndex != -1) {
String latStr = rawInput.substring(0, commaIndex);
String lonStr = rawInput.substring(commaIndex+1);
if (colonIndex != -1) {
lonStr = rawInput.substring(commaIndex+1, colonIndex);
float lat = latStr.toFloat();
float lon = lonStr.toFloat();
if (lat != 0 && lon != 0) {
GeoLoc waypoint;
waypoint.lat = lat;
waypoint.lon = lon;
Serial.print("Waypoint found: "); Serial.print(lat); Serial.println(lon);
driveTo(waypoint, GPS_WAYPOINT_TIMEOUT);
rawInput = rawInput.substring(colonIndex + 1);
} while (colonIndex != -1);
void displayCompassDetails(void)
sensor_t sensor;
mag.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" uT");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" uT");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" uT");
Serial.println("");
#ifndef DEGTORAD
#define DEGTORAD 0.0174532925199432957f
#define RADTODEG 57.295779513082320876f
#endif
float geoBearing(struct GeoLoc &a, struct GeoLoc &b) {
float y = sin(b.lon-a.lon) * cos(b.lat);
float x = cos(a.lat)*sin(b.lat) - sin(a.lat)*cos(b.lat)*cos(b.lon-a.lon);
return atan2(y, x) * RADTODEG;
float geoDistance(struct GeoLoc &a, struct GeoLoc &b) {
const float R = 6371000; // km
float p1 = a.lat * DEGTORAD;
float p2 = b.lat * DEGTORAD;
float dp = (b.lat-a.lat) * DEGTORAD;
float dl = (b.lon-a.lon) * DEGTORAD;
float x = sin(dp/2) * sin(dp/2) + cos(p1) * cos(p2) * sin(dl/2) * sin(dl/2);
float y = 2 * atan2(sqrt(x), sqrt(1-x));
return R * y;
float geoHeading() {
/* Get a new sensor event */
sensors_event_t event;
mag.getEvent(&event);
// Hold the module so that Z is pointing 'up' and you can measure the heading with x&y
// Calculate heading when the magnetometer is level, then correct for signs of axis.
float heading = atan2(event.magnetic.y, event.magnetic.x);
// Offset
heading -= DECLINATION_ANGLE;
heading -= COMPASS_OFFSET;
// Correct for when signs are reversed.
if(heading < 0)
heading += 2*PI;
// Check for wrap due to addition of declination.
if(heading > 2*PI)
heading -= 2*PI;
// Convert radians to degrees for readability.
float headingDegrees = heading * 180/M_PI;
// Map to -180 - 180
while (headingDegrees < -180) headingDegrees += 360;
while (headingDegrees > 180) headingDegrees -= 360;
return headingDegrees;
void setSpeedMotorA(int speed) {
digitalWrite(MOTOR_A_IN_1_PIN, LOW);
digitalWrite(MOTOR_A_IN_2_PIN, HIGH);
// set speed to 200 out of possible range 0~255
analogWrite(MOTOR_A_EN_PIN, speed + MOTOR_A_OFFSET);
void setSpeedMotorB(int speed) {
digitalWrite(MOTOR_B_IN_1_PIN, LOW);
digitalWrite(MOTOR_B_IN_2_PIN, HIGH);
analogWrite(MOTOR_B_EN_PIN, speed + MOTOR_B_OFFSET);
void setSpeed(int speed)
// this function will run the motors in both directions at a fixed speed
// turn on motor A
setSpeedMotorA(speed);
// turn on motor B
setSpeedMotorB(speed);
void stop() {
// now turn off motors
digitalWrite(MOTOR_A_IN_2_PIN, LOW);
digitalWrite(MOTOR_B_IN_2_PIN, LOW);
void drive(int distance, float turn) {
int fullSpeed = 230;
int stopSpeed = 0;
// drive to location
int s = fullSpeed;
if ( distance < 8 ) {
int wouldBeSpeed = s - stopSpeed;
wouldBeSpeed *= distance / 8.0f;
s = stopSpeed + wouldBeSpeed;
int autoThrottle = constrain(s, stopSpeed, fullSpeed);
autoThrottle = 230;
float t = turn;
while (t < -180) t += 360;
while (t > 180) t -= 360;
Serial.print("turn: ");
Serial.println(t);
Serial.print("original: ");
Serial.println(turn);
float t_modifier = (180.0 - abs(t)) / 180.0;
float autoSteerA = 1;
float autoSteerB = 1;
if (t < 0) {
autoSteerB = t_modifier;
} else if (t > 0){
autoSteerA = t_modifier;
Serial.print("steerA: "); Serial.println(autoSteerA);
Serial.print("steerB: "); Serial.println(autoSteerB);
int speedA = (int) (((float) autoThrottle) * autoSteerA);
int speedB = (int) (((float) autoThrottle) * autoSteerB);
setSpeedMotorA(speedA);
setSpeedMotorB(speedB);
void driveTo(struct GeoLoc &loc, int timeout) {
nss.listen();
GeoLoc coolerLoc = checkGPS();
bluetoothSerial.listen();
if (coolerLoc.lat != 0 && coolerLoc.lon != 0 && enabled) {
float d = 0;
//Start move loop here
do {
nss.listen();
d = geoDistance(coolerLoc, loc);
float t = geoBearing(coolerLoc, loc) - geoHeading();
Serial.print("Distance: ");
Serial.println(geoDistance(coolerLoc, loc));
Serial.print("Bearing: ");
Serial.println(geoBearing(coolerLoc, loc));
Serial.print("heading: ");
Serial.println(geoHeading());
drive(d, t);
timeout -= 1;
} while (d > 3.0 && enabled && timeout>0);
stop();
void setupCompass() {
/* Initialise the compass */
if(!mag.begin())
/* There was a problem detecting the HMC5883 ... check your connections */
Serial.println("Ooops, no HMC5883 detected ... Check your wiring!");
while(1);
/* Display some basic information on this sensor */
displayCompassDetails();
// Compass
setupCompass();
// Motor pins
pinMode(MOTOR_A_EN_PIN, OUTPUT);
pinMode(MOTOR_B_EN_PIN, OUTPUT);
pinMode(MOTOR_A_IN_1_PIN, OUTPUT);
pinMode(MOTOR_A_IN_2_PIN, OUTPUT);
pinMode(MOTOR_B_IN_1_PIN, OUTPUT);
pinMode(MOTOR_B_IN_2_PIN, OUTPUT);
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
//Debugging via serial
Serial.begin(4800);
//GPS
nss.begin(9600);
//Bluetooth
bluetoothSerial.begin(9600);
Blynk.begin(bluetoothSerial, auth);
// Testing
void testDriveNorth() {
float heading = geoHeading();
int testDist = 10;
Serial.println(heading);
while(!(heading < 5 && heading > -5)) {
drive(testDist, heading);
stop();
Blynk.run();
And here is the error I'm getting:
Arduino: 1.8.14 (Windows 10), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\2021josiahwright\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10814 -build-path C:\Users\2021JO~1\AppData\Local\Temp\arduino_build_441911 -warnings=all -build-cache C:\Users\2021JO~1\AppData\Local\Temp\arduino_cache_888186 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\2021josiahwright\Documents\Arduino\actualsketch\actualsketch.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\2021josiahwright\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10814 -build-path C:\Users\2021JO~1\AppData\Local\Temp\arduino_build_441911 -warnings=all -build-cache C:\Users\2021JO~1\AppData\Local\Temp\arduino_cache_888186 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\2021josiahwright\Documents\Arduino\actualsketch\actualsketch.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\2021JO~1\AppData\Local\Temp\arduino_build_441911\sketch\actualsketch.ino.cpp" -o nul
Alternatives for SoftwareSerial.h: [SoftwareSerial@1.0]
ResolveLibrary(SoftwareSerial.h)
-> candidates: [SoftwareSerial@1.0]
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "C:\Users\2021JO~1\AppData\Local\Temp\arduino_build_441911\sketch\actualsketch.ino.cpp" -o nul
Alternatives for TinyGPS.h: [TinyGPS@13.0.0]
ResolveLibrary(TinyGPS.h)
-> candidates: [TinyGPS@13.0.0]
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "C:\Users\2021JO~1\AppData\Local\Temp\arduino_build_441911\sketch\actualsketch.ino.cpp" -o nul
Alternatives for Blynk.h: [Blynk@0.4.4]
ResolveLibrary(Blynk.h)
-> candidates: [Blynk@0.4.4]
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src" "C:\Users\2021JO~1\AppData\Local\Temp\arduino_build_441911\sketch\actualsketch.ino.cpp" -o nul
Alternatives for Adafruit_HMC5883_U.h: [Adafruit_HMC5883_Unified@1.2.0]
ResolveLibrary(Adafruit_HMC5883_U.h)
-> candidates: [Adafruit_HMC5883_Unified@1.2.0]
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified" "C:\Users\2021JO~1\AppData\Local\Temp\arduino_build_441911\sketch\actualsketch.ino.cpp" -o nul
Alternatives for Adafruit_Sensor.h: [Adafruit_Unified_Sensor@1.1.4]
ResolveLibrary(Adafruit_Sensor.h)
-> candidates: [Adafruit_Unified_Sensor@1.1.4]
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "C:\Users\2021JO~1\AppData\Local\Temp\arduino_build_441911\sketch\actualsketch.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\2021JO~1\AppData\Local\Temp\arduino_build_441911\sketch\actualsketch.ino.cpp" -o nul
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src\SoftwareSerial.cpp" -o nul
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src\TinyGPS.cpp" -o nul
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp" -o nul
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src\utility\BlynkHandlers.cpp" -o nul
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src\utility\utility.cpp" -o nul
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified\Adafruit_HMC5883_U.cpp" -o nul
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_Unified_Sensor\Adafruit_Sensor.cpp" -o nul
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\Wire.cpp" -o nul
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c" -o nul
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\2021JO~1\AppData\Local\Temp\arduino_build_441911\sketch\actualsketch.ino.cpp" -o "C:\Users\2021JO~1\AppData\Local\Temp\arduino_build_441911\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\2021JO~1\AppData\Local\Temp\arduino_build_441911\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10814 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified" "-IC:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_Unified_Sensor" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\2021JO~1\AppData\Local\Temp\arduino_build_441911\sketch\actualsketch.ino.cpp" -o "C:\Users\2021JO~1\AppData\Local\Temp\arduino_build_441911\sketch\actualsketch.ino.cpp.o"
In file included from C:\Users\2021josiahwright\Documents\Arduino\actualsketch\actualsketch.ino:5:0:
C:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk\src/Blynk.h:15:2: warning: #warning "Please include a board-specific header file, instead of Blynk.h (see examples)" [-Wcpp]
C:\Users\2021josiahwright\Documents\Arduino\actualsketch\actualsketch.ino: In function 'void BlynkWidgetWrite2(BlynkReq&, const BlynkParam&)':
actualsketch:131:20: error: 'class TinyGPS' has no member named 'getLat'
actualsketch:131:73: error: 'class TinyGPS' has no member named 'getLon'
actualsketch:134:22: error: 'class TinyGPS' has no member named 'getLat'
actualsketch:135:22: error: 'class TinyGPS' has no member named 'getLon'
C:\Users\2021josiahwright\Documents\Arduino\actualsketch\actualsketch.ino: In function 'void setup()':
actualsketch:398:3: error: 'Blynk' was not declared in this scope
C:\Users\2021josiahwright\Documents\Arduino\actualsketch\actualsketch.ino:398:3: note: suggested alternative: 'Blynk_h'
Blynk_h
C:\Users\2021josiahwright\Documents\Arduino\actualsketch\actualsketch.ino: In function 'void loop()':
actualsketch:419:3: error: 'Blynk' was not declared in this scope
Blynk.run();
C:\Users\2021josiahwright\Documents\Arduino\actualsketch\actualsketch.ino:419:3: note: suggested alternative: 'Blynk_h'
Blynk.run();
Blynk_h
Using library SoftwareSerial at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial
Using library TinyGPS at version 13.0.0 in folder: C:\Users\2021josiahwright\Documents\Arduino\libraries\TinyGPS
Using library Blynk at version 0.4.4 in folder: C:\Users\2021josiahwright\Documents\Arduino\libraries\Blynk
Using library Adafruit_HMC5883_Unified at version 1.2.0 in folder: C:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_HMC5883_Unified
Using library Adafruit_Unified_Sensor at version 1.1.4 in folder: C:\Users\2021josiahwright\Documents\Arduino\libraries\Adafruit_Unified_Sensor
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
exit status 1
