I made a library from Jeff Saltzman button reading code but I am getting some errors when trying to use and compile it in my sketch:
/Users/admin/Documents/Arduino/libraries/Button/Button.h:17: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Button'
/Users/admin/Documents/Arduino/libraries/Button/Button.c:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
/Users/admin/Documents/Arduino/libraries/Button/Button.c:51: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
Here is the arduino sketch:
#include <Button.h>
#define mybuttonPin 19
#define ledPin1 17 // digital output pin for LED 1
#define ledPin2 16 // digital output pin for LED 2
#define ledPin3 15 // digital output pin for LED 3
#define ledPin4 14 // digital output pin for LED 4
Button myButton(mybuttonPin);
// LED variables
boolean ledVal1 = false; // state of LED 1
boolean ledVal2 = false; // state of LED 2
boolean ledVal3 = false; // state of LED 3
boolean ledVal4 = false; // state of LED 4
// Set LED output pins
pinMode(ledPin1, OUTPUT);
digitalWrite(ledPin1, ledVal1);
pinMode(ledPin2, OUTPUT);
digitalWrite(ledPin2, ledVal2);
pinMode(ledPin3, OUTPUT);
digitalWrite(ledPin3, ledVal3);
pinMode(ledPin4, OUTPUT);
digitalWrite(ledPin4, ledVal4);
// Get button event and act accordingly
int b = myButton.checkButton();
if (b == 1) clickEvent();
if (b == 2) doubleClickEvent();
if (b == 3) holdEvent();
if (b == 4) longHoldEvent();
// Events to trigger by click and press+hold
void clickEvent()
ledVal1 = !ledVal1;
void doubleClickEvent()
ledVal2 = !ledVal2;
void holdEvent()
ledVal3 = !ledVal3;
void longHoldEvent()
ledVal4 = !ledVal4;
and the library files:
Button.h:
* Button.h
* Library Created by Danjel van Tijn on 30/10/09 using code from
* Jeff Saltzman Oct. 13, 2009 .
#ifndef Button_h
#define Button_h
#include "WProgram.h"
class Button
public:
Button(int pin);
int checkButton();
// Button timing variables
int debounce; // ms debounce period to prevent flickering when pressing or releasing the button
int DCgap; // max ms between clicks for a double click event
int holdTime; // ms hold period: how long to wait for press+hold event
int longHoldTime; // ms long hold period: how long to wait for press+hold event
private:
int buttonPin
boolean buttonVal; // value read from button
boolean buttonLast; // buffered value of the button's previous state
boolean DCwaiting; // whether we're waiting for a double click (down)
boolean DConUp; // whether to register a double click on next release, or whether to wait and click
boolean singleOK; // whether it's OK to do a single click
long downTime; // time the button was pressed down
long upTime; // time the button was released
boolean ignoreUp; // whether to ignore the button release because the click+hold was triggered
boolean waitForUp; // when held, whether to wait for the up event
boolean holdEventPast; // whether or not the hold event happened already
boolean longHoldEventPast;// whether or not the long hold event happened already
#endif
Button.c:
* Button.c
#include "Button.h"
* Constructor
Button::Button(int pin)
buttonPin = pin;
pinMode(buttonPin, INPUT);
digitalWrite(buttonPin, HIGH );
debounce = 20; // ms debounce period to prevent flickering when pressing or releasing the button
DCgap = 250; // max ms between clicks for a double click event
holdTime = 2000; // ms hold period: how long to wait for press+hold event
longHoldTime = 5000; // ms long hold period: how long to wait for press+hold event
// Other button variables
buttonVal = HIGH; // value read from button
buttonLast = HIGH; // buffered value of the button's previous state
DCwaiting = false; // whether we're waiting for a double click (down)
DConUp = false; // whether to register a double click on next release, or whether to wait and click
singleOK = true; // whether it's OK to do a single click
downTime = -1; // time the button was pressed down
upTime = -1; // time the button was released
ignoreUp = false; // whether to ignore the button release because the click+hold was triggered
waitForUp = false; // when held, whether to wait for the up event
holdEventPast = false; // whether or not the hold event happened already
longHoldEventPast = false;// whether or not the long hold event happened already
* Public methods
int Button::checkButton()
int event = 0;
// Read the state of the button
buttonVal = digitalRead(buttonPin);
// Button pressed down
if (buttonVal == LOW && buttonLast == HIGH && (millis() - upTime) > debounce)
downTime = millis();
ignoreUp = false;
waitForUp = false;
singleOK = true;
if ((millis()-upTime) < DCgap && DConUp == false && DCwaiting == true) DConUp = true;
else DConUp = false;
DCwaiting = false;
// Button released
else if (buttonVal == HIGH && buttonLast == LOW && (millis() - downTime) > debounce)
if (not ignoreUp)
upTime = millis();
if (DConUp == false) DCwaiting = true;
event = 2;
DConUp = false;
DCwaiting = false;
singleOK = false;
// Test for normal click event: DCgap expired
if ( buttonVal == HIGH && (millis()-upTime) >= DCgap && DCwaiting == true && DConUp == false && singleOK == true)
event = 1;
DCwaiting = false;
// Test for hold
if (buttonVal == LOW && (millis() - downTime) >= holdTime)
// Trigger "normal" hold
if (not holdEventPast)
event = 3;
waitForUp = true;
ignoreUp = true;
DConUp = false;
DCwaiting = false;
//downTime = millis();
holdEventPast = true;
// Trigger "long" hold
if ((millis() - downTime) >= longHoldTime)
if (not longHoldEventPast)
event = 4;
longHoldEventPast = true;
buttonLast = buttonVal;
return event;
