Errors in compiling sketches with Ethernet Shield DFROBOT based on W5200
Hello
I am using a DFROBOT Ethernet W5200 shield with UNO. I downloaded the library from: https://github.com/jbkim/W5200-Arduino-Ethernet-library. I installed it per the instructions in the README file.
After compilation, I got the following message several times:
libraries/\Ethernet\src\Ethernet.cpp: 'SPI_ETHERNET_SETTINGS' was not declared in this scope
I tried several ethernet sketches from the ethernet examples in the IDE and I got the same compilation errors. Can anybody help with this issue?
Thanks for any idea
Mike
That's a super outdated library. Try this one instead: https://github.com/per1234/EthernetMod/tree/W5x00
I downloaded the library you recommended. My sketch works perfect with this library, with no need to define the ethernet controller.
Thank you very much Pert
Mike
