I’m trying to compile the basic Blink program using Atmel Studio 6. I’ve followed engblaze’s tutorial to setup the project in Atmel Studio 6.1. However, I still get errors.
Here is the code,
#include <avr/io.h>
#include <Arduino.h>
#include <pins_arduino.h>
int main(void)
void setup(void);
void loop(void);
int led = 13;
pinMode(led, OUTPUT);
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
And here are the error and warning messages,
Error 1 a function-definition is not allowed here before '{' token C:\Hrishis Documents\Atmel Studio\6.1\ArduinoBlink\ArduinoBlink\ArduinoBlink.cpp 27 2 ArduinoBlink
Error 2 a function-definition is not allowed here before '{' token C:\Hrishis Documents\Atmel Studio\6.1\ArduinoBlink\ArduinoBlink\ArduinoBlink.cpp 32 2 ArduinoBlink
Warning 3 unused variable 'led' [-Wunused-variable] C:\Hrishis Documents\Atmel Studio\6.1\ArduinoBlink\ArduinoBlink\ArduinoBlink.cpp 24 6 ArduinoBlink
Whats going wrong here? Any help would be appreciated. Thanks.
Thanks dc42! However, I still get the same errors I know these are really basic questions but I’ve just started out with C and C++ and I really appreciate your help!
Here is the updated code,
#include <avr/io.h>
void setup();
void loop();
int main(void)
int led = 13;
void setup(void)
void loop(void)
The problem in your second code is that you actually put the functions inside main(). The example shown to you was just a declaration of a function… it was
void setup(void);
which only shows the return value datatype and the argument(s) data type.
I wonder, though, why you are writing it with main().
A sketch with only a setup() and loop() is really all you need.
You moved the prototypes, not the functions. It should be:
#include <avr/io.h>
int led = 13;
void setup(void)
void loop(void)
int main(void)
init ();
while (true)
loop ();
