Evening All
Im trying to pars a string received through the serial port. The fields are separated by # and the command ends with a .
Ive cut the code down to make it more readable but the problems are the same. the 'sdt#1234' command only has 2 fields in it and it seems to work. (Although something freezes up occasionally).
The second command 'ov#1#345*' , usually the 'ov' part is identified, but the program mostly seems to freeze while extracting the '1' and has never got as far as the 3rd field.
Ive done VERY little embedded programming although have an amount of experience with VC++. (I really miss my de-bug environment !!).
Id be very greatfull if anyone can help me out with this, its driving me nuts !!!!!
the code below will compile and run if you have the inclination. the strings Im sending down the serial port are
sdt#1234*
ov#1#345*
Thanks Very much in advance for your time !
Phil
/* COMMS MESSAGE
sdt#VALUE* Sets Sequence Delay to a given value *=End Marker
dc#DRIP_ID#START|STOP(1 | 0)#FORM_TIME#DELAY* Drip Control Empty field = no change
sys#START|STOP(1 | 0)* Start or stop running
dd#NUMBER* do 'number' amount of drips
ov#TIME* open valve for TIME ms
struct open_valve_struct{
int open_valve;
int run_time;
} Open_valve = {0,5000};
struct do_drip_struct{
boolean do_drip;
int drip_number;
} Do_Drip = {0,5};
struct drip_struct{
boolean active;
int drip_delay;
int drip_form_time;
} drip_1 = {1,0,30},
drip_2 = {0,85,30},
drip_3 = {0,85,30},
drip_4 = {0,85,30};
drip_struct* DripArray[] = {&drip_1,&drip_2,&drip_3,&drip_4};
int ValvePin = 3;
unsigned long Sequence_Delay = 3500; //ms
int DripsInSequence = 1;
String CmdInStr;
boolean MsgComplete = false;
int Running = 0;
boolean Ready = false;
long previousMillis = 0;
boolean TimeToGo = false;
String MsgDest;
// initialize serial communication:
Serial.flush();
pinMode(ValvePin, OUTPUT);
digitalWrite(ValvePin, LOW);
void ReadSerialPort()
while (Serial.available()&& MsgComplete == false)
char c = Serial.read();
CmdInStr += c;
if(c == '*')//msg end
MsgComplete = true;
} //while
void GetActionCmd()
String tmpStr1;
int pos1 = CmdInStr.indexOf('#');
if(pos1 == -1)
pos1 = CmdInStr.indexOf('*');
MsgDest = CmdInStr.substring(0,pos1);
tmpStr1 = CmdInStr.substring(pos1 + 1, CmdInStr.length());
CmdInStr = tmpStr1;
Serial.print(F("CmdInStr = "));Serial.print(CmdInStr);Serial.print(F("\r\n"));
tmpStr1 = "";
void ActionMessage()
int drip_id =0;
void* tp;
MsgDest = "";
GetActionCmd();
if(MsgDest == "sdt")//sequ delay time
GetActionCmd();
tp = malloc(MsgDest.length());
MsgDest.toCharArray((char*)tp,MsgDest.length()+1);
Sequence_Delay = atoi((char*)tp);
Serial.print(F("Sequence_Delay = "));Serial.print(Sequence_Delay);Serial.print(F("\r\n"));
CmdInStr = "";
free((void*) tp);
MsgDest = "";
if(MsgDest == "ov")//open valve
Serial.print("ov \r\n");
GetActionCmd();
Open_valve.open_valve = atoi((char*)tp);
Serial.print(F(" Open_valve.open_valve = "));Serial.print( Open_valve.open_valve);Serial.print(F("\r\n"));
CmdInStr = "";
free((void*) tp);
MsgDest = "";
GetActionCmd();
Open_valve.run_time = atoi((char*)tp);
Serial.print(F("Open_valve.run_time = "));Serial.print(Open_valve.run_time);Serial.print(F("\r\n"));
CmdInStr = "";
free((void*) tp);
MsgDest = "";
MsgComplete = false; // re-set so new commands can be recieved
ReadSerialPort();
if (MsgComplete == true)
ActionMessage();
Serial.print(F(". .... \r\n"));
