PeterH:
That's a library, not a sketch. Can you post your sketch too?
#define ledPin 13
#define lcdoutPin 7
#include "LCDSerial.h"
LCDSerial lcdSerial = LCDSerial(lcdoutPin);
#include "wiichuck_funcs.h"
// sensor data in form:
// "|xxyyzz|xxyyzz|....\n"
// where 'xx','yy','zz'. are each a byte in ascii hex, 3-bytes per data payload
// terminated with newline
// every this many millisecs, read sensors, should be even mult of 1000
#define sensorUpdatesPerSec 10
#define sensorUpdateMillis (1000/sensorUpdatesPerSec)
#define SENSORBUFFSIZE (3*sensorUpdatesPerSec)
// overhead
#define sensorUpdateMillisWFudge (sensorUpdateMillis - 10)
uint8_t sensorbuff[SENSORBUFFSIZE];
uint8_t sensorbuffidx;
uint8_t sensor_max[3];
uint8_t sensor_min[3];
uint8_t sensor_offsets[3] = // zero-offsets, with initial guess
127,127,127
//128, // x
//143, // y
//180 // z
#define sensor_range 4 // wii nunchuck accelerometer is +/- 2g => 4g total
// see http://wiire.org/Chips/LIS3L02AL
#define BUFFSIZE 75
char buffer[BUFFSIZE]; // this is the double buffer
uint8_t bufferidx;
char timebuff[7] = "hhddss";
uint8_t i;
unsigned long lasttime;
unsigned long lastctrltime;
uint8_t disp_mode; // 0 = rec/play, 1 = max, 2 = min, 3 = lat/ong
uint8_t rec_mode = 0; // 1 = record, 0 = pause/stop
uint8_t key_down;
uint8_t display_gees = 0;
#define DISP_REC 0
#define DISP_MAX 1
#define DISP_MIN 2
pinMode( ledPin, OUTPUT);
digitalWrite( ledPin, HIGH);
Serial.begin(4800); // This goes to data logger
Serial.println("WiiCoasterUI");
lcdSerial.begin(9600); // this goes to the LCD, don't change baud!
lcdSerial.clearScreen();
lcdSerial.print("WiiCoasterUI");
wiichuck_setpowerpins();
delay(100);
wiichuck_begin();
// initialize any data that needs to be specific values
memset(sensor_max, 0, 3);
memset(sensor_min, 255,3);
digitalWrite( ledPin, LOW);
// returns ascii hex nibble
static char toHex(uint8_t h)
h &= 0xf;
if( h < 10 )
return (h + '0');
return (h - 10 + 'A');
// take a signed number, format it as a string into buff
static void formatInt8(char* buff, int8_t v)
buff[0] = (v>0) ? '+':'-';
buff[1] = ((abs(v)/100) %10) + '0';
buff[2] = ((abs(v)/10) %10) + '0';
buff[3] = ((abs(v)/1) %10) + '0';
buff[4] = 0;
// turn a signed float byte into a character string
// this likely has lots of bugs
void formatFloat8(char* buff, int8_t v, float range)
v = abs(v);
float f = (v*range/127)/2;
buff[1] = (int)f + '0';
buff[2] = '.';
buff[3] = ((int)(f*10) %10) + '0';
buff[4] = 0;
// convert milliseconds to a hour/min/sec string
static void millisToTimeStr( char* buff, unsigned long millis )
long secs = millis/1000;
long mins = secs/60;
int hours = mins/60;
secs = secs % 60;
mins = mins % 60;
buff[0] = (hours/10)+ '0'; // hours tens
buff[1] = (hours%10)+ '0'; // hours ones
buff[2] = (mins/10) + '0'; // mins tens
buff[3] = (mins%10) + '0'; // mins ones
buff[4] = (secs/10) + '0'; // secs tens
buff[5] = (secs%10) + '0'; // secs ones
buff[6] = 0;
char c;
digitalWrite(ledPin, LOW);
unsigned long thistime = millis();
// wait until it's the right time
if( (thistime - lasttime) >= sensorUpdateMillisWFudge ) {
lasttime = thistime;
digitalWrite(ledPin, HIGH); // turn off "good data" LED so it pulses
// Acquire sensor readings
wiichuck_get_data();
for( i=0; i<3; i++ ) { // loop thru x,y,z parts
uint8_t v = wiichuck_accelbuf[i];
if( v > sensor_max[i] && v!=255 ) sensor_max[i] = v;
if( v < sensor_min[i] && v!=0 ) sensor_min[i] = v;
// Save data
memcpy(sensorbuff+sensorbuffidx, wiichuck_accelbuf, 3);
sensorbuffidx += 3;
if( sensorbuffidx == SENSORBUFFSIZE ) {
sensorbuffidx = 0; // just loop, what else we gonna do?
// Do UI Parsing
if( wiichuck_cbutton() ) { // C button == clear min/max
memset(sensor_max, 0, 3); // reset maxs to 0
memset(sensor_min, 255,3); // reset mins to 255
display_gees = !display_gees;
//for( i=0; i<3; i++ )
// sensor_offsets[i] = wiichuck_accelbuf[i]; // FIXME: wrong
if( wiichuck_zbutton() ) { // Z button == stop/start recording
key_down = 1; // keydown is for debounce
if( !wiichuck_zbutton() && key_down ) {
rec_mode = !rec_mode;
key_down = 0;
// pick display mode based on inputs
if( wiichuck_joyy() > 0xA0 ) disp_mode = DISP_MAX;
else if( wiichuck_joyy() < 0x40 ) disp_mode = DISP_MIN;
else disp_mode = DISP_REC;
// move stick to the right changes readout style
if( wiichuck_joyx() > 0xA0 )
// Write to LCD
lcdSerial.gotoPos(0,0); // line 1
if( disp_mode == DISP_MAX )
lcdSerial.print("Max");
else if( disp_mode == DISP_MIN )
lcdSerial.print("Min");
lcdSerial.print( (rec_mode) ? "Rec":"Stp");
lcdSerial.gotoPos(0,7);
// if no time from controller
if( thistime - lastctrltime > 5000 ) {
millisToTimeStr( timebuff, thistime );
// print out time
lcdSerial.print( timebuff[0] );
lcdSerial.print( timebuff[1] );
lcdSerial.print( ':' );
lcdSerial.print( timebuff[2] );
lcdSerial.print( timebuff[3] );
lcdSerial.print( timebuff[4] );
lcdSerial.print( timebuff[5] );
lcdSerial.gotoPos(1,0); // line 2
lcdSerial.print( (display_gees) ? "g:":"w:" );
char buff[5];
for( i=0; i<3; i++) {
uint8_t v;
if( disp_mode==DISP_MAX ) v = sensor_max[i];
else if( disp_mode==DISP_MIN ) v = sensor_min[i];
else v = wiichuck_accelbuf[i];
if( display_gees ) {
int8_t vo = v - sensor_offsets[i];
formatFloat8( buff, vo, sensor_range ); // range is +/- 2g => 4
formatInt8( buff, v - 127);
lcdSerial.print( buff );
if(i!=2) lcdSerial.print(',');
// Over serial, can ask for last 10 readings with 'sensor dump command'
// get sensor dump commands from serial
int n = Serial.available();
if( n > 6 ) { // "s221359", 7 bytes
char c = Serial.read();
if( c != 's' && c!='S' ) // command byte
return;
// do rest of parsing, for time
for( i=0; i<6; i++ )
timebuff[i] = Serial.read();
delay(5); // this is needed or SoftSerial reading this will choke
Serial.print( (rec_mode) ? 'r':'s' );
// fill buffer with text version of sensor data
bufferidx = 0;
for( i=0; i< sensorUpdatesPerSec; i++) {
uint8_t si = (i*3);
buffer[bufferidx+0] = '|';
buffer[bufferidx+1] = toHex(sensorbuff[si+0]>>4);
buffer[bufferidx+2] = toHex(sensorbuff[si+0]);
buffer[bufferidx+3] = toHex(sensorbuff[si+1]>>4);
buffer[bufferidx+4] = toHex(sensorbuff[si+1]);
buffer[bufferidx+5] = toHex(sensorbuff[si+2]>>4);
buffer[bufferidx+6] = toHex(sensorbuff[si+2]);
bufferidx+=7;
buffer[bufferidx++] = '\r';
buffer[bufferidx] = '\n';
buffer[bufferidx+1] = 0;
Serial.print(buffer); // dump it out
sensorbuffidx = 0; // reset
memset(sensorbuff, 0, sizeof(sensorbuff));
lastctrltime = millis(); // say we saw a command
