I'm using my Arduino Uno to read a stepper motor and a few sensors. I count the steps using interrupts, and so far it works fine up to ~120kHz (I've tested it using another Arduino).
However problems occur when I use external power supply and do not have it plugged into my pc: The Arduino seems to work fine, but it miscounts even even at speeds of 0.1 - 1 kHz, although I do not even use any serial communication.
I would appreciate if someone could help me, after all it should work the same way with an external power source?
I've attached a simplified version of the source code.
Yours, prooq
#define encoderPinA 2 // Encoder pins
#define encoderPinB 3
#include <LiquidCrystal.h>
volatile long int encoder; // Encoder position
volatile byte Aold; // Last encoder states
volatile byte Bold; // (volatile declarations for interrupt variables)
long int old_encoder; // Last position
LiquidCrystal lcd(5, 6, 7, 8, 9, 10, 11);
randomSeed(analogRead(0));
digitalWrite(encoderPinA, HIGH); // Turn on pullup resistors on encder pins
pinMode(encoderPinA, INPUT); // and set pins to input.
digitalWrite(encoderPinB, HIGH);
pinMode(encoderPinB, INPUT);
Aold = digitalRead(encoderPinA); // Read initial state of encoder
Bold = digitalRead(encoderPinB);
attachInterrupt(0, doEncoderA, CHANGE); // Encoder A on interrupt 0 (pin 2)
attachInterrupt(1, doEncoderB, CHANGE); // Encoder B on interrupt 1 (pin 3)
old_encoder = encoder; // Enter peacefully (no position change yet)
lcd.begin(16,2);
lcd.print("Encoder position");
void loop(){
if (old_encoder != encoder) { // Check for changes in encoder position
old_encoder = encoder; // Encoder changed; reset old encoder position
lcd.setCursor(0,1);
lcd.print(encoder);
void doEncoderA(){ // Interrupt on A (pin 2)
Aold == Bold ? encoder++ : encoder--; // increase : decrease encoder value
Aold = !Aold; // update state of pin A
void doEncoderB(){ // Interrupt on B (pin 3)
Aold != Bold ? encoder++ : encoder--; // increase : decrease encoder value
Bold = !Bold; // update state of pin B
