Errors on tutorial code
I just got this code here:
And went to compile, to see if it would work, but it wouldn't. I just can't figure out what are the problems.
   Pachube sensor client with Strings
  This sketch connects an analog sensor to Pachube (http://www.pachube.com)
  using a Wiznet Ethernet shield. You can use the Arduino Ethernet shield, or
  the Adafruit Ethernet shield, either one will work, as long as it's got
  a Wiznet Ethernet module on board.
  This example has been updated to use version 2.0 of the Pachube.com API.
  To make it work, create a feed with two datastreams, and give them the IDs
  sensor1 and sensor2. Or change the code below to match your feed.
  This example uses the String library, which is part of the Arduino core from
  version 0019.
  Circuit:
  * Analog sensor attached to analog in 0
  * Ethernet shield attached to pins 10, 11, 12, 13
  created 15 March 2010
  updated 16 Mar 2012
  by Tom Igoe with input from Usman Haque and Joe Saavedra
  http://arduino.cc/en/Tutorial/PachubeClientString
  This code is in the public domain.
#include <SPI.h>
#include <Ethernet.h>
#define APIKEY         "YOUR API KEY GOES HERE" // replace your pachube api key here
#define FEEDID         00000 // replace your feed ID
#define USERAGENT      "My Project" // user agent is the project name
// assign a MAC address for the ethernet controller.
// fill in your address here:
   byte mac[] = {
   0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
// fill in an available IP address on your network here,
// for manual configuration:
 IPAddress ip(10,0,1,20);
// initialize the library instance:
 EthernetClient client;
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(216,52,233,122);      // numeric IP for api.pachube.com
char server[] = "api.pachube.com";   // name address for pachube API
unsigned long lastConnectionTime = 0;          // last time you connected to the server, in milliseconds
boolean lastConnected = false;                 // state of the connection last time through the main loop
 const unsigned long postingInterval = 10*1000;  //delay between updates to Pachube.com
   // start serial port:
   // give the ethernet module time to boot up:
   // start the Ethernet connection:
   if (Ethernet.begin(mac) == 0) {
     Serial.println("Failed to configure Ethernet using DHCP");
     // DHCP failed, so use a fixed IP address:
     Ethernet.begin(mac, ip);
   // read the analog sensor:
   int sensorReading = analogRead(A0);
   // convert the data to a String to send it:
   String dataString = "sensor1,";
   dataString += sensorReading;
   // you can append multiple readings to this String if your
   // pachube feed is set up to handle multiple values:
   int otherSensorReading = analogRead(A1);
   dataString += "\nsensor2,";
   dataString += otherSensorReading;
   // if there's incoming data from the net connection.
   // send it out the serial port.  This is for debugging
   // purposes only:
   if (client.available()) {
     char c = client.read();
     Serial.print(c);
   // if there's no net connection, but there was one last time
   // through the loop, then stop the client:
   if (!client.connected() && lastConnected) {
     Serial.println("disconnecting.");
     client.stop();
   // if you're not connected, and ten seconds have passed since
   // your last connection, then connect again and send data:
   if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
     sendData(dataString);
   // store the state of the connection for next time through
   // the loop:
   lastConnected = client.connected();
// this method makes a HTTP connection to the server:
void sendData(String thisData) {
   // if there's a successful connection:
   if (client.connect(server, 80)) {
     Serial.println("connecting...");
     // send the HTTP PUT request:
     client.print("PUT /v2/feeds/");
     client.print(FEEDID);
     client.println(".csv HTTP/1.1");
     client.println("Host: api.pachube.com");
     client.print("X-PachubeApiKey: ");
     client.println(APIKEY);
     client.print("User-Agent: ");
     client.println(USERAGENT);
     client.print("Content-Length: ");
     client.println(thisData.length());
     // last pieces of the HTTP PUT request:
     client.println("Content-Type: text/csv");
     client.println("Connection: close");
     client.println();
     // here's the actual content of the PUT request:
     client.println(thisData);
   else {
     // if you couldn't make a connection:
     Serial.println("connection failed");
     client.stop();
   // note the time that the connection was made or attempted:
   lastConnectionTime = millis();
I don't think there's anything wrong with the sketch. I've just compiled it without any issues.
Which version of the IDE are you using?
That code compiles fine under 1.0, but may fail on earlier versions (thought those errors look more like IDE failures rather than compilation - I realise for you the distinction is very fine and largely irrelevant, but it is important to us)
AWOL:
I'm using Arduino 1.0, so, if this is IDE failures, how to I solve it?
EDIT: I ran javaw.exe and it worked. Thanks
