Errors when loading sketch..any ideas?
So I have Arduino version 1.0.6 and I am having an issue just opening my saved code.
It will open with a new sketch ready to start coding so that is working, but when i try to open my code it gives this in the error bar:
Exception in thread "AWT-EventQueue-0" java.lang.ArrayIndexOutOfBoundsException: 0
at processing.app.Sketch.setCurrentCode(Sketch.java:1177)
at processing.app.Sketch.load(Sketch.java:215)
at processing.app.Sketch.(Sketch.java:137)
at processing.app.Editor.handleOpenInternal(Editor.java:2193)
at processing.app.Editor.(Editor.java:304)
at processing.app.Base.handleOpen(Base.java:709)
at processing.app.Base.handleOpen(Base.java:674)
at processing.app.Base.handleOpenPrompt(Base.java:663)
at processing.app.Editor$4.actionPerformed(Editor.java:499)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1225)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1266)
at java.awt.Component.processMouseEvent(Component.java:6263)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6028)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Does any of the example sketches open OK.
Yes they open fine.
I think I got it figured out. I found a thread with my similar problem and someone there was helpful.
Thanks!
