Can someone help please; my sketch has been working and compiling perfectly for Mega2560 but I get the following errors when compiling for Due. First part of errors and sketch only pasted because it exceeds a character limit!
Arduino: 1.8.5 (Windows 10), Board: "Arduino Due (Programming Port)"
F:\Documents\Arduino\Channelizer Due\Rack_1 - Copy\Rack_1\Rack_1.ino: In function 'void loop()':
Rack_1:284: error: invalid conversion from 'byte {aka unsigned char}' to 'midi::MidiType' [-fpermissive]
portLo);
In file included from F:\Documents\Arduino\libraries\arduino_841278\src/MIDI.h:258:0,
from F:\Documents\Arduino\Channelizer Due\Rack_1 - Copy\Rack_1\Rack_1.ino:8:
F:\Documents\Arduino\libraries\arduino_841278\src/MIDI.hpp:133:6: error: initializing argument 1 of 'void midi::MidiInterface<SerialPort, _Settings>::send(midi::MidiType, midi::DataByte, midi::DataByte, midi::Channel) [with SerialPort = HardwareSerial; _Settings = midi::DefaultSettings; midi::DataByte = unsigned char; midi::Channel = unsigned char]' [-fpermissive]
void MidiInterface<SerialPort, Settings>::send(MidiType inType,
Rack_1:292: error: invalid conversion from 'byte {aka unsigned char}' to 'midi::MidiType' [-fpermissive]
7);
#include <MIDI.h>
#include <button.h>
#include <midi-utils.h>
#include <ntools.h>
#define USE_OLED_64_ADAFRUIT
#include <XLCD.h>
#define OLED_RESET 13
Adafruit_SSD1306 display(OLED_RESET);
long timeoutLimit = 375000;//approx 1250 per second or 75,000 per minute
long timeoutCount = 0;
bool turnOnDisplay = true;
bool displayIsOn = true;
#define MODE_IDLE 0
#define MODE_SPLIT 3
#define UNISON (keySplit == 21)
byte _note = 0;
byte Data1T;
byte Data1Lo;
byte Data1Hi;
byte Data2;
boolean CC33 = false; //set if midi CC33 incoming - don't send to Peak!
byte shrunkData1Lo;
byte shrunkData1Hi;
byte shrunkData1T;
byte shrunkData2;
String drawData1;
String drawData2 = "flabs ";
byte portT = 7;
float denominator = 4;
int fourteenBit;
byte MidiType;
byte Mode = MODE_IDLE;
byte lastMode = MODE_IDLE;
// reduce screen flickering
boolean needsUpdate = true;
boolean doSkip = false;
boolean dataToDisplay = false;
// to avoid hangs, the keydowns are counted, if > 0 the blue LED is lid
int keysDown = 0;
//Default split point: Lower zone 0 (C-1) to 35 (B2); Upper zone 36 (C3) to 127 (G9)
// changed to start in UNISON Mode
byte keySplit = 21;
Button _upLower(53); //increase the lower output Channel
Button _downLower(51); //decrease the lower output Channel
Button _upUpper(47); //increase the upper output Channel
Button _downUpper(45); //decrease the upper output Channel
Button _setSplit(43); //ask for note on Keysplit or return to Unison mode if pressed with no note entered
Button _panic(49); //parachute
Button upperTransUp(35);
Button upperTransDown(37);
Button lowerTransUp(39);
Button lowerTransDown(41);
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
boolean toggleA = false; //panel switch A shrinks range of Pitch Bend wheel for Mini D on Channel 6
boolean toggleB = false; //panel switch B echo's everything on Ch 6 to Ch 7 so that Odyssey and mini D are treated as single synth and PB etc. goes to both
byte portHi;
byte portLo;
byte transposeHi;
byte transposeLo;
char whoAmI; //which of four Arduinos in the rack am I? A,B,C,D.
LCD_BEGIN
//Serial.begin(9600);
lcd << L(3, 1) << F("Channelizer");
lcd << L(3, 2) << F("By Steve Hunt");
lcd << L(3, 3) << F("");
lcd << L(3, 4) << __DATE__ ;
lcd << L(3, 5) << __TIME__ ;
pinMode(23,INPUT_PULLUP);
pinMode(25,INPUT_PULLUP);
pinMode(27,INPUT_PULLUP);
pinMode(29,INPUT_PULLUP);
pinMode(31,INPUT_PULLUP);
pinMode(33,INPUT_PULLUP);
lcd.display();
delay (800);
MIDI.begin(MIDI_CHANNEL_OMNI);
MIDI.turnThruOff();
if ( digitalRead(27)== LOW ) whoAmI = 'A';
else if ( digitalRead(29)== LOW ) whoAmI = 'B';
else if ( digitalRead(31)== LOW ) whoAmI = 'C';
else if ( digitalRead(33)== LOW ) whoAmI = 'D';
else whoAmI = 'Z';
//First power-on state:
//whoAmI = 'C';
switch (whoAmI) {
case 'A':
portHi = 1;
portLo = 0;
transposeHi = 0;
transposeLo = 0;
case 'B':
portHi = 2;
portLo = 0;
transposeHi = 0;
transposeLo = 0;
case 'C':
portHi = 3;
portLo = 0;
transposeHi = 0;
transposeLo = 0;
case 'D':
portHi = 6;
portLo = 0;
transposeHi = 0;
transposeLo = 0;
default:
portHi = 5;
portLo = 0;
transposeHi = 0;
transposeLo = 0;
timeoutCount++;
if (timeoutCount > timeoutLimit)
display.begin(SSD1306_SWITCHCAPVCC, 0x3c); // initialize with the I2C addr 0x3C (for the 128x64)
display.ssd1306_command(SSD1306_DISPLAYOFF); // To switch display off
turnOnDisplay = false;
displayIsOn = false;
timeoutCount = 0; //prevents overflow
if (turnOnDisplay)
display.ssd1306_command(SSD1306_DISPLAYON); // To switch display back on
displayIsOn = true;
lastMode = Mode;
CC33 = false;
if (MIDI.read())
Data1Lo = Data1Hi = Data1T = MIDI.getData1();
Data2 = MIDI.getData2();
MidiType = MIDI.getType();
switch (MidiType)
case midi::NoteOn:
keysDown++;
timeoutCount = 0;
_note = MIDI.getData1();
if (Mode == MODE_SPLIT)
keySplit = _note;
portT = portHi;
lastMode = MODE_SPLIT;
Mode = MODE_IDLE;
needsUpdate = true;
goto cont;
Data1Lo += transposeLo;
Data1Hi += transposeHi;
if (_note < keySplit)
portT = portLo;
Data1T = Data1Lo;
portT = portHi;
Data1T = Data1Hi;
if (keysDown > 24) keysDown = 0;
noteSend();
case midi::NoteOff:
timeoutCount = 0;
if (!displayIsOn) turnOnDisplay = true;
portT = portLo;
Data1T = Data1Lo;
portT = portHi;
Data1T = Data1Hi;
keysDown--;
if (keysDown < 0) keysDown = 0;
noteSend();
case midi::AfterTouchPoly: // = 0xA0,
case midi::ControlChange: // = 0xB0,
if (MIDI.getData1() == 33 ) CC33 = true; //CC33 dropped so that Numa mod wheel doesn't fool Peak into changing osc 1 lfo shape ammount at extreme of mod wheel range
portT = portHi; // anything except note ons and offs are sent to PortHi - unless Unison mode...
if (UNISON)
// if we are in UNISON Mode, we forward all cc etc to both ports
if (portLo && !(portLo == 5 && CC33)) // ie skip if we've selected midi channel 0 or if (CC33 and Peak)
//if (!(portLo == 7 && portHi == 6 && toggleB)) //don't echo out on Ch7 if also echoing on other zone
if (portLo == 6 && toggleA) {Data1Lo = shrunkData1Lo; Data2 = shrunkData2;}
MIDI.send(MidiType,
Data1Lo,
Data2,
portLo);
if (portLo == 6 && toggleB) // toggleB echo's everything on Ch6 to Ch7 as well
MIDI.send(MidiType,
Data1Lo,
Data2,
7);
if (portHi && !(portHi == 5 && CC33)) // ie skip if we've selected midi channel 0 or if (CC33 and Peak)
if (portLo != portHi) //so if both zones are same channel don't send duplicate notes or CC
MIDI.send(MidiType,
Data1Hi,
Data2,
portHi);
if (portHi == 6 && toggleB) // toggleB echo's everything on Ch6 to Ch7 as well
MIDI.send(MidiType,
Data1Hi,
Data2,
7);
