Hi everyone. Forgive me but I'm pretty new at this and am learning as I go. I've been trying to set up the firmware for my new ERYONE Thinker SE to use my BLTouch. I've found an instructional video at this link [Tutorial] How to upload the firmware to thinker S - YouTube
Everything seems to be going well, I compile the sketch, no issues.
Then I upload and get the following error (attached) and I'm not sure why.
Can anyone help? I'm a little slow so please be patient with me.
Error.txt (214 KB)
The interesting bit from the error log.
Used: G:arduinolibrariesU8glib
Not used: G:arduinolibrariesU8glib_Arduino-master
Using library U8glib at version 1.19.1 in folder: G:arduinolibrariesU8glib
Using library SPI at version 1.0 in folder: C:Program Files (x86)ArduinohardwarearduinoavrlibrariesSPI
"C:\Users\squir\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-size" -A "C:\Users\squir\AppData\Local\Temp\arduino_build_815413/Marlin.ino.elf"
Sketch uses 147628 bytes (58%) of program storage space. Maximum is 253952 bytes.
Global variables use 5086 bytes (62%) of dynamic memory, leaving 3106 bytes for local variables. Maximum is 8192 bytes.
avrdude: ser_open(): can't set com-state for "\.COM11"
avrdude: ser_drain(): read error: The handle is invalid.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
the selected serial port avrdude: stk500v2_getsync(): timeout communicating with programmer
does not exist or your board is not connected
Remove ANY connections to the board apart from the USB or ICSP programmer.
A link to the EXACT board itself would be appreciated.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
