Errors with code for MINI UNTZTRUMENT project
Hello, I am having problems with code provide by an adafruit tutorial for the mini untztrument.
This is the code they provided to use.
#include <Wire.h>
#include <Adafruit_Trellis.h>
#define LED     13 // Pin for heartbeat LED (shows code is working)
#define CHANNEL 1  // MIDI channel number
Adafruit_Trellis trellis;
uint8_t       heart        = 0;  // Heartbeat LED counter
unsigned long prevReadTime = 0L; // Keypad polling timer
uint8_t       mod;
uint8_t       vel;
uint8_t       fxc;
uint8_t       rate;
uint8_t note[] = {
  60, 61, 62, 63,
  56, 57, 58, 59,
  52, 53, 54, 55,
  48, 49, 50, 51
  pinMode(LED, OUTPUT);
  trellis.begin(0x70); // Pass I2C address
#ifdef __AVR__
  // Default Arduino I2C speed is 100 KHz, but the HT16K33 supports
  // 400 KHz.  We can force this for faster read & refresh, but may
  // break compatibility with other I2C devices...so be prepared to
  // comment this out, or save & restore value as needed.
  TWBR = 12;
#endif
  trellis.clear();
  trellis.writeDisplay();
  mod = map(analogRead(0), 0, 1023, 0, 127);
  vel = map(analogRead(1), 0, 1023, 0, 127);
  fxc = map(analogRead(2), 0, 1023, 0, 127);
  rate = map(analogRead(3),0, 1023, 0, 127);
  usbMIDI.sendControlChange(1, mod, CHANNEL);
  usbMIDI.sendControlChange(11, vel, CHANNEL);
  usbMIDI.sendControlChange(12, fxc, CHANNEL);
  usbMIDI.sendControlChange(13, rate, CHANNEL);
  unsigned long t = millis();
  if((t - prevReadTime) >= 20L) { // 20ms = min Trellis poll time
    if(trellis.readSwitches()) {  // Button state change?
      for(uint8_t i=0; i<16; i++) { // For each button...
        if(trellis.justPressed(i)) {
          usbMIDI.sendNoteOn(note[i], 127, CHANNEL);
          trellis.setLED(i);
        } else if(trellis.justReleased(i)) {
          usbMIDI.sendNoteOff(note[i], 0, CHANNEL);
          trellis.clrLED(i);
    uint8_t newModulation = map(analogRead(0), 0, 1023, 0, 127);
    if(mod != newModulation) {
      mod = newModulation;
    uint8_t newVelocity = map(analogRead(1), 0, 1023, 0, 127);
    if(vel != newVelocity) {
      vel = newVelocity;
    uint8_t newEffect = map(analogRead(2), 0, 1023, 0, 127);
    if(fxc != newEffect) {
      fxc = newEffect;
    uint8_t newRate = map(analogRead(3), 0, 1023, 0, 127);
    if(rate !=newRate) {
      rate = newRate;
    prevReadTime = t;
    digitalWrite(LED, ++heart & 32); // Blink = alive
  while(usbMIDI.read()); // Discard incoming MIDI messages
These are the error messages that I receive.
Arduino: 1.8.8 (Windows 10), TD: 1.45, Board: “Arduino Leonardo”
C:\Users\loxyluvsrandom\Documents\Arduino\miniuntz\miniuntz.ino: In function ‘void setup()’:
miniuntz:49:3: error: ‘usbMIDI’ was not declared in this scope
C:\Users\loxyluvsrandom\Documents\Arduino\miniuntz\miniuntz.ino: In function ‘void loop()’:
miniuntz:62:11: error: ‘usbMIDI’ was not declared in this scope
usbMIDI.sendNoteOn(note*, 127, CHANNEL);*
    miniuntz:66:11: error: ‘usbMIDI’ was not declared in this scope
    _ usbMIDI.sendNoteOff(note*, 0, CHANNEL);_
    _
    ^_
    miniuntz:75:7: error: ‘usbMIDI’ was not declared in this scope
    _
    usbMIDI.sendControlChange(1, mod, CHANNEL);_
    _
    ^_
    miniuntz:80:7: error: ‘usbMIDI’ was not declared in this scope
    _
    usbMIDI.sendControlChange(11, vel, CHANNEL);_
    _
    ^_
    miniuntz:85:7: error: ‘usbMIDI’ was not declared in this scope
    _
    usbMIDI.sendControlChange(12, fxc, CHANNEL);_
    _
    ^_
    miniuntz:90:7: error: ‘usbMIDI’ was not declared in this scope
    _
    usbMIDI.sendControlChange(13, rate, CHANNEL);_
    _
    ^_
    miniuntz:95:9: error: ‘usbMIDI’ was not declared in this scope
    _
    while(usbMIDI.read()); // Discard incoming MIDI messages*_
    exit status 1
    Sorry if there are multiple errors in this post.
    I am just trying to finish this project but this issue with the code is holding me up. I have looked everywhere for help on this project and there is nothing to be found.
    PLEASE HELP!!
You are missing the code for the usbMIDI routines, whatever those might be.
Consider posting on the Adafruit forum.
