I have read all the posts here and found a lot of usefull stuff. I am using IDE 1.0.1 on a Modern Devices RBBB.
However, I still can't get any of the DS3231 examples to compile and run. I keep getting the following errors;
ds3231_set:128: error: redefinition of 'DS3231 Clock'
ds3231_set:14: error: 'DS3231 Clock' previously declared here
ds3231_set:130: error: redefinition of 'byte Year'
ds3231_set:16: error: 'byte Year' previously declared here
ds3231_set:131: error: redefinition of 'byte Month'
ds3231_set:17: error: 'byte Month' previously declared here
ds3231_set:132: error: redefinition of 'byte Date'
ds3231_set:18: error: 'byte Date' previously declared here
ds3231_set:133: error: redefinition of 'byte DoW'
ds3231_set:19: error: 'byte DoW' previously declared here
ds3231_set:134: error: redefinition of 'byte Hour'
ds3231_set:20: error: 'byte Hour' previously declared here
ds3231_set:135: error: redefinition of 'byte Minute'
ds3231_set:21: error: 'byte Minute' previously declared here
ds3231_set:136: error: redefinition of 'byte Second'
ds3231_set:22: error: 'byte Second' previously declared here
DS3231_set.cpp: In function 'void GetDateStuff(byte&, byte&, byte&, byte&, byte&, byte&, byte&)':
ds3231_set:139: error: redefinition of 'void GetDateStuff(byte&, byte&, byte&, byte&, byte&, byte&, byte&)'
ds3231_set:25: error: 'void GetDateStuff(byte&, byte&, byte&, byte&, byte&, byte&, byte&)' previously defined here
DS3231_set.cpp: In function 'void setup()':
ds3231_set:188: error: redefinition of 'void setup()'
ds3231_set:74: error: 'void setup()' previously defined here
DS3231_set.cpp: In function 'void loop()':
ds3231_set:196: error: redefinition of 'void loop()'
ds3231_set:82: error: 'void loop()' previously defined here
Would appreciate any help..........Thanks
