errors with readPixel for HX8357 TFT (Adafruit 3.5") [solved]
I couldn’t find “readPixel” code on-line for the HX8357D controller, so I wrote the code below. It is intended to read the color code of a pixel on the Adafruit 3.5" TFT.
In the uppermost code window:
With “red” in the code (btwn the *****), the red, dark green, and yellow pixel color codes are correct, but magenta and grey are wrong (equal to zero).
Without “red” in the code, the magenta, dark green, and yellow pixels are correct, but grey is still 0x0.
In the lower code window, magenta, yellow, dark green, and grey are all correct, regardless whether “red” is in the code or out.
Same results with 1.6.5-r5 and 1.0.5. Windows 7 64-bit. Nano w/ 328
HX8357D controller datasheet Memory read command is on page 149 of 254.
HX8357 Library My “read” code is based on their readcommand8 function (near bottom of the .cpp)
I would appreciate some help figuring this out.
This works, sometimes:
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_HX8357.h"
const byte TFT_DC = 9;
const byte TFT_CS = 10;
const byte TFT_CLK = 13;
// RGB565 colors
const unsigned int GREY = 0xDF1C; // 1101111100011100
const unsigned int DKGREEN = 0x1BE0; // 0001101111100000
Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC);
  Serial.println("HX8357D Test");
  tft.begin(HX8357D);
  tft.fillScreen(HX8357_BLACK);
  TEST by deleting this code
  tft.drawPixel(15,15,HX8357_RED);
  readPixA(15,15);
  Serial.println(F("Red    : 1111100000000000")); // <- should be this
  tft.drawPixel(10,10,HX8357_MAGENTA);
  readPixA(10,10);
  Serial.println(F("Magenta: 1111100000011111")); // <- should be this
  tft.drawPixel(5,5,HX8357_YELLOW);
  tft.drawPixel(7,3,GREY);
  tft.drawPixel(10,10,DKGREEN); // change 10,10 to dark green
  readPixA(10,10);
  Serial.println(F("DkGreen: 0001101111100000"));
  readPixA(5,5);
  Serial.println(F("Yellow:1111111111100000"));
  readPixA(7,3);
  Serial.println(F("Grey:  1101111100011100"));
void readPixA(int x, int y) {
  tft.setAddrWindow(x,y,x,y);
  Serial.print(x);
  Serial.print(" ");
  Serial.print(y);
  Serial.print("  0b");
  digitalWrite(TFT_DC, LOW);
  digitalWrite(TFT_CLK, LOW);
  digitalWrite(TFT_CS, LOW);
  tft.spiwrite(0x2E); // memory read command
  digitalWrite(TFT_DC, HIGH);
  uint16_t r = 0;
  r = tft.spiread(); // discard dummy read
  r = tft.spiread() >> 3; // red: use 5 highest bits (discard three LSB)
  r = (r << 6) | tft.spiread() >> 2; // green: use 6 highest bits (discard two LSB)
  r = (r << 5) | tft.spiread() >> 3; // blue: use 5 highest bits (discard three LSB)
  prntBIN16(r);
// print binary with leading zero padding
void prntBIN16(uint16_t numToPrnt) {
  for (unsigned long mask = 0x8000; mask; mask >>= 1) {
    Serial.print(mask&numToPrnt?'1':'0');
This works, apparently all the time:
#include <SPI.h>
const unsigned int LTRED = 0xFE79;
  tft.begin(HX8357D);
  Serial.print("RED:   ");
  readPixB();
  Serial.println("should be: 1111100000000000");
  Serial.print("Magenta:   ");
  readPixB();
  Serial.println("should be: 1111100000011111");
  Serial.print("Yellow:    ");
  readPixB();
  Serial.println("should be: 1111111111100000");
  Serial.print("Grey:      ");
  readPixB();
  Serial.println("should be: 1101111100011100");
  Serial.print("DkGreen:   ");
  readPixB();
  Serial.println("should be: 0001101111100000");
  readPixA(10,10);
  Serial.println("DkGreen: 0001101111100000");
  readPixA(5,5);
  Serial.println("Yellow:1111111111100000");
  readPixA(7,3);
  Serial.println("Grey:  1101111100011100");
void readPixB() {
  uint16_t r = 0;
  prntBIN16(r);
  Serial.print(x);
  Serial.print(" ");
  Serial.print(y);
  uint16_t r = 0;
  prntBIN16(r);
Results from code in lower window (everything is hunky dory):
Only results without red shown…
HX8357D Test
Yellow:    1111111111100000
10 10  0b0001101111100000
5 5  0b1111111111100000
7 3  0b1101111100011100
Results from code in upper window:
HX8357D Test
15 15  0b1111100000000000  <-- with Red
10 10  0b0000000000000000  <-- Magenta FAILS
10 10  0b0001101111100000  <-- DkGreen is ok
5 5  0b1111111111100000    <-- Yellow is ok
7 3  0b0000000000000000    <-- Grey FAILS
HX8357D Test
10 10  0b1111100000011111  <- without Red, Magenta is now ok
7 3  0b0000000000000000    <- Grey still FAILS
Never mind. I found the error.
  prntBIN16(r);
should have been
  digitalWrite(TFT_CS, HIGH);
  prntBIN16(r);
Yay!
Corrected code:
// read the RGB565 color code of a pixel
// on the Adafruit 3.5" TFT with HX8357D controller
#include <SPI.h>
/*  Used for testing:
 *  Magenta: 11111 000000 11111
 *  DkGreen: 00011 011111 00000
 *  Yellow:  11111 111111 00000
 *  Grey:    11011 111000 11100
 *  Red:     11111 000000 00000
 *  LtRed:   11111 110011 11001
 *  const unsigned int GREY = 0xDF1C;
 *  const unsigned int LTRED = 0xFE79;
 *  const unsigned int DKGREEN = 0x1BE0;
  tft.begin(HX8357D);
  tft.fillScreen(HX8357_RED);
  prntBIN16(readPixA(200,200));
uint16_t readPixA(int x, int y) {
  uint16_t r = 0;
  return r;
