Hi guys, i need your help. I'm trying to connect my Node-MCU Esp-8266 to Alexa, but when i try to compile my sketch, it doesn't finish, and send me this error message:
In file included from C:\Users\Zammarrelli Giuseppe\Documents\Arduino\libraries\arduinoWebSockets-2.1.4\src\libb64\cencode.c:9:0:
C:\Users\Zammarrelli Giuseppe\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.6.1\cores\esp8266/core_esp8266_features.h:88:1: error: unknown type name 'uint32_t'
inline uint32_t esp_get_cycle_count() attribute((always_inline));
C:\Users\Zammarrelli Giuseppe\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.6.1\cores\esp8266/core_esp8266_features.h:89:1: error: unknown type name 'uint32_t'
inline uint32_t esp_get_cycle_count() {
C:\Users\Zammarrelli Giuseppe\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.6.1\cores\esp8266/core_esp8266_features.h: In function 'esp_get_cycle_count':
C:\Users\Zammarrelli Giuseppe\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.6.1\cores\esp8266/core_esp8266_features.h:90:3: error: unknown type name 'uint32_t'
uint32_t ccount;
C:\Users\Zammarrelli Giuseppe\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.6.1\cores\esp8266/core_esp8266_features.h: At top level:
C:\Users\Zammarrelli Giuseppe\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.6.1\cores\esp8266/core_esp8266_features.h:112:24: error: unknown type name 'uint32_t'
void precache(void *f, uint32_t bytes);
In file included from C:\Users\Zammarrelli Giuseppe\Documents\Arduino\libraries\arduinoWebSockets-2.1.4\src\libb64\cdecode.c:9:0:
uint32_t ccount;
void precache(void f, uint32_t bytes);
Uso la libreria ESP8266WiFi alla versione 1.0 nella cartella: C:\Users\Zammarrelli Giuseppe\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.6.1\libraries\ESP8266WiFi
Uso la libreria arduinoWebSockets-2.1.4 alla versione 2.1.4 nella cartella: C:\Users\Zammarrelli Giuseppe\Documents\Arduino\libraries\arduinoWebSockets-2.1.4
Uso la libreria ArduinoJson alla versione 5.13.2 nella cartella: C:\Users\Zammarrelli Giuseppe\Documents\Arduino\libraries\ArduinoJson
Uso la libreria Hash alla versione 1.0 nella cartella: C:\Users\Zammarrelli Giuseppe\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.6.1\libraries\Hash
exit status 1
Errore durante la compilazione per la scheda NodeMCU 1.0 (ESP-12E Module).
If you doesn't understand some parts of code, i'll translate it for you.
Here is the sketch:
Version 0.3 - March 06 2018
Grensom Version
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <WebSocketsClient.h>
#include <ArduinoJson.h>
#include <StreamString.h>
ESP8266WiFiMulti WiFiMulti;
WebSocketsClient webSocket;
WiFiClient client;
#define MyApiKey "220e651d-5aad-49d6-8176-05a4421105d8"
#define MySSID "DESKTOP-HM9N8TL 3214"
#define MyWifiPassword "ciaooooo"
#define HEARTBEAT_INTERVAL 300000
uint64_t heartbeatTimestamp = 0;
bool isConnected = false;
void setPowerStateOnServer(String deviceId, String value);
void setTargetTemperatureOnServer(String deviceId, String value, String scale);
void turnOn(String deviceId) {
if (deviceId == "5ddfd61d97b25c41bd4e4db0")
Serial.print("Turn on device id: ");
Serial.println(deviceId);
else if (deviceId == "5ddfd61d97b25c41bd4e4db0")
else {
Serial.print("Turn on for unknown device id: ");
void turnOff(String deviceId) {
Serial.print("Turn off Device ID: ");
else {
Serial.print("Turn off for unknown device id: ");
void webSocketEvent(WStype_t type, uint8_t * payload, size_t length) {
switch(type) {
case WStype_DISCONNECTED:
Serial.printf("[WSc] Webservice disconnected from sinric.com!\n");
case WStype_CONNECTED: {
isConnected = true;
Serial.printf("[WSc] Service connected to sinric.com at url: %s\n", payload);
Serial.printf("Waiting for commands from sinric.com ...\n");
case WStype_TEXT: {
Serial.printf("[WSc] get text: %s\n", payload);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject((char*)payload);
String deviceId = json ["deviceId"];
String action = json ["action"];
if(action == "setPowerState") {
String value = json ["value"];
if(value == "ON") {
turnOn(deviceId);
turnOff(deviceId);
else if (action == "SetTargetTemperature") {
else if (action == "test") {
Serial.println("[WSc] received test command from sinric.com");
case WStype_BIN:
Serial.printf("[WSc] get binary length: %u\n", length);
WiFiMulti.addAP(MySSID, MyWifiPassword);
Serial.print("Connecting to Wifi: ");
Serial.println(MySSID);
// Waiting for Wifi connect
while(WiFiMulti.run() != WL_CONNECTED) {
Serial.print(".");
if(WiFiMulti.run() == WL_CONNECTED) {
Serial.println("");
Serial.print("WiFi connected. ");
Serial.print("IP address: ");
webSocket.begin("iot.sinric.com", 80, "/");
webSocket.onEvent(webSocketEvent);
webSocket.setAuthorization("apikey", MyApiKey);
webSocket.setReconnectInterval(5000);
webSocket.loop();
if(isConnected) {
uint64_t now = millis();
if((now - heartbeatTimestamp) > HEARTBEAT_INTERVAL) {
heartbeatTimestamp = now;
webSocket.sendTXT("H");
void setPowerStateOnServer(String deviceId, String value) {
JsonObject& root = jsonBuffer.createObject();
root["deviceId"] = deviceId;
root["action"] = "setPowerState";
root["value"] = value;
StreamString databuf;
root.printTo(databuf);
webSocket.sendTXT(databuf);
void setTargetTemperatureOnServer(String deviceId, String value, String scale) {
root["action"] = "SetTargetTemperature";
JsonObject& valueObj = root.createNestedObject("value");
JsonObject& targetSetpoint = valueObj.createNestedObject("targetSetpoint");
targetSetpoint["value"] = value;
targetSetpoint["scale"] = scale;
