To preface my post, I am developing a mobile robot which should travel predetermined distance and come to a halt at the target after traversing a predetermined path. I use a BLDC motor with ESC to drive the robot and the microcontroller, sensors, arduino code manage the actions. I use laser for target pointing.
The sequence of set up activities includes 1) esc calibration, 2) laser pointing to align the vehicle and 3) then flipping on a SPST switch to let the microcontroller know to accelerate the mobile robot.
I am experiencing an unpredictable behavior at the moment. After complete set up steps 1 and 2 above, which is about 2 mins, the vehicle doesn't start immediately after flipping the switch. Rather it takes about 8~10 seconds to start and then start moving.
I researched that this could be due to fail safe mechanism built into esc. So, I keep alternating between two relatively close Neutral PWM signals to prevent the robot and motor from entering into fail safe mode. However, this has not been reliable. It sometimes starts immediately when the switch is turned on after laser aiming, and at other times it takes 8~10 seconds to start. Could you please explain to me what could be going on here?
You probably have a bad connection or maybe it is a problem in the code or maybe it is the power supply or maybe its ???? Without your code and an annotated schematic showing how you wired this the odds of getting a good answer are slim.
