Hi, i am making a rc car project and I cant seem to figure out how to use an esc (traxxas XL5hv) with arduino. Basicly what im trying to do is add a ultra sonic sensor to the front of my rc car and everytime it comes close to a wall it should slow down and stop, I just want the motor be controlled through the arduino so I can add the sensor if you have any other Ideas I am ready to hear them. I am using a FLYSKY FS-i6x controller , the code I used as a refrance:
https://dronebotworkshop.com/radio-control-arduino-car/
^to use FlySky fs-i6x with arduino^
https://bluerobotics.com/learn/guide-for-controlling-the-basic-esc-with-a-potentiometer/
^to control the ESC using with an PWM output^
I just cant seem to find how to control my esc with arduino. Ive tryed to use the control an ESC with PWM(and a pot) and change some code to take my controller as an input but the motor spins its just the motor idles at mid point. I can include a video if you dont understand what I mean or even a diragram.
Code:
#include <Servo.h>
// Define Input Connections
#define CH1 8
byte servoPin = 9; // signal pin for the ESC.
Servo servo;
int minLimit;
int maxLimit;
// Integers to represent values from sticks and pots
int ch1Value;
int readChannel(int channelInput, int minLimit, int maxLimit, int defaultValue){
int ch = pulseIn(channelInput, HIGH, 30000);
if (ch < 100) return defaultValue;
return map(ch, 1000, 2000, minLimit, maxLimit);
// Read the switch channel and return a boolean value
bool readSwitch(byte channelInput, bool defaultValue){
int intDefaultValue = (defaultValue)? 100: 0;
int ch = readChannel(channelInput, 0, 100, intDefaultValue);
return (ch > 50);
void setup(){
// Set up serial monitor
// Set all pins as inputs
pinMode(CH1, INPUT);
servo.attach(servoPin);
servo.writeMicroseconds(1500); // send "stop" signal to ESC. Also necessary to arm the ESC.
// Get values for each channel
ch1Value = readChannel(CH1, -100, 100, 0);
// Print to Serial Monitor
Serial.println(ch1Value);
int pwmVal = map(ch1Value,0, 1023, 1100, 1900); // maps potentiometer values to PWM value.
servo.writeMicroseconds(pwmVal); // Send signal to ESC.
Note: The motor should go forward and Reverse (50/50).
Thanks alot for reading Ive been stuck here for the past week!
