Hey Guys & Gals thanks for taking the time to read this.
I'm a noob but I'm not looking for anyone to write code just point me in the right direction of what command I should be researching.
I'm building a motion activated light sensor for my Escape Room.
For testing code I'm just using the arduino uno 1 led & a PIR sensor
Here's what I've been trying to do.
Start with led off.
Watch for motion for 20 seconds. (not wait 20 seconds & read the PIR)
Once 20 seconds pass without motion detected turn led back on.
Turn the led off immediately if motion is detected.
I'm struggling with coding the 20 second wait period.
I took my delay out of the code because all they do is wait to read which isn't what I want.
I know there's a simple code out there to fix this I just don't know where to look. Am I correct that a Delay isn't what I need?
I'm thinking I need to have the PIR read once a second, keeping a running count of low reads on the PIR and once that count reaches a number greater than 20 turn on the led. Any help at all is greatly appreciated.
int pir = 2;
int light = 13;
{pinMode(pir, INPUT);
pinMode(light, OUTPUT);}
{long sensor = digitalRead(pir);
if(sensor == HIGH){
digitalWrite (light, LOW);}
{digitalWrite (light, HIGH);}}
** EDIT - Jumped the Gun on this post, I think I know what I did wrong though, I don't need hints**
Thanks Delta_G! It's working! All I needed to know was millis.
int pir = 2;
int light = 13;
int timePir;
int time;
time = millis();
if(sensor == HIGH){
timePir = millis();
else if (timePir > time - 20000)
As PaulS noticed I have almost no experience. Until asking this question everything I had learned was on my own. Sorry the code is so ugly, I was unaware and thought it looked more organized without all the white space. I'll make sure to use the auto format before posting again.
I changed my else if and added comments, but somethings still not quite right.
Is it possible that when I'm tripping the PIR sensor it's not at that place in the loop and not recording the event to the timePir variable? It almost seems like a short motion trigger isn't getting the 20 second delay while a bunch of motion does get the delay.
The 20 second delay works about 50% of the time the PIR is tripped but the other 50% of the time the light turns back on immediately. I'm ready for another hint.
int pir = 2;
int light = 13;
int timePir;
int time;
long sensor = digitalRead(pir); //read the PIR
time = millis(); //set variable time to millis time
if(sensor == HIGH){ //if the PIR is detecting motion
timePir = millis(); //set variable time PIR to millis time
digitalWrite (light, LOW); //turn the light off
else if (time > timePir + 20000) // if variable time is greater than variable timePir + 20 seconds
digitalWrite (light, HIGH); //turn the light back on
Also, why use a long to store a digitalRead() ? A byte will suffice, or avoid to store it at all :
if(digitalRead(pir) == HIGH){ //if the PIR is detecting motion
In a small sketch like this one doesn't not make big difference of course, but avoid to waste the limited (especially for RAM) resource is a good coding pratice.
