Hey, i got an isue:
got esp01 connected to the internet and mqtt server and relay,when i run all things connected without light bulb connected to the relay, i got all things are ok, but when i connect light bulb to the relay esp restarts
following connections:
Arduino
rx,tx to esp rx,tx
5vcc to esp and relay vcc input
gnd to esp and relay gnd
and following code:
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// Define NodeMCU D3 pin connect to LED
const int LED_PIN = 2;
// Update these with values suitable for your network.
const char* ssid = "";
const char* password = "";
const char* mqtt_server = "";
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
void setup_wifi() {
delay(100);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
randomSeed(micros());
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
void callback(char* topic, byte* payload, unsigned int length)
Serial.print("Command from MQTT broker is : [");
Serial.print(topic);
int p =(char)payload[0]-'0';
// if MQTT comes a 0 turn off LED on D2
if(p==0)
digitalWrite(LED_PIN, LOW);
Serial.println(" Turn Off LED! " );
// if MQTT comes a 1, turn on LED on pin D2
if(p==1)
digitalWrite(LED_PIN, HIGH);
Serial.println(" Turn On LED! " );
} //end callback
void reconnect() {
// Loop until we're reconnected
while (!client.connected())
Serial.print("Attempting MQTT connection...");
// Create a random client ID
String clientId = "ESP8266Client-";
clientId += String(random(0xffff), HEX);
// Attempt to connect
//if you MQTT broker has clientID,username and password
//please change following line to if (client.connect(clientId,userName,passWord))
if (client.connect(clientId.c_str()))
Serial.println("connected");
//once connected to MQTT broker, subscribe command if any
client.subscribe("room/lamp");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 6 seconds before retrying
delay(6000);
} //end reconnect()
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
pinMode(LED_PIN, OUTPUT);
if (!client.connected()) {
reconnect();
client.loop();
