ESP-01 uploading to SPIFFS error
I am using an ESP-01 and i get the following error when i tried to upload a blank test sketch to SPIFFS. I have a data folder inside the sketch folder which contains a txt file with some random words just to test. I followed the same method as to upload a sketch to the ESP-01, that is, connect GPIO 2 to ground and pulse Reset pin to ground, then i clicked on Tools > ESP8266 Sketch Data Upload.
I am using Arduino IDE 1.8.11 and i verified if my Flash Size setting was correct for my ESP-01, by uploading this sketch: Arduino/CheckFlashConfig.ino at master · esp8266/Arduino · GitHub and the Serial Monitor showed that it is OK. So, my generic ESP-01 module has a Flash chip size of 1MB and a file system size of 64KB.
This is the error shown in Arduino IDE compilation window:
[SPIFFS] data    : /home/user/Arduino/Introducing_SPIFFS/data
[SPIFFS] size    : 64
[SPIFFS] page    : 256
[SPIFFS] block   : 4096
/test_example
[SPIFFS] upload  : /tmp/arduino_build_672275/Introducing_SPIFFS.spiffs.bin
[SPIFFS] address  : 0xEB000
[SPIFFS] reset    : --before default_reset --after hard_reset
[SPIFFS] port     : /dev/ttyUSB0
[SPIFFS] speed    : 115200
[SPIFFS] python   : python
[SPIFFS] uploader : /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.2/tools/upload.py
usage: esptool [-h] [--chip {auto,esp8266,esp32}] [--port PORT] [--baud BAUD]
               [--before {default_reset,no_reset,no_reset_no_sync}]
               [--after {hard_reset,soft_reset,no_reset}] [--no-stub]
               [--trace] [--override-vddsdio [{1.8V,1.9V,OFF}]]
               {load_ram,dump_mem,read_mem,write_mem,write_flash,run,image_info,make_image,elf2image,read_mac,chip_id,flash_id,read_flash_status,write_flash_status,read_flash,verify_flash,erase_flash,erase_region,version}
esptool: error: unrecognized arguments: --end
SPIFFS Upload failed!
Does it make sense to upload a sketch to SPIFFS ?
What are you going to do with it if you manage to upload it ?
I am using this guide: Install ESP8266 Filesystem Uploader in Arduino IDE | Random Nerd Tutorials and in the first step:
  1. Create an Arduino sketch and save it. For demonstration purposes, you can save an empty sketch.
This is my first time experimenting with SPIFFS on ESP-01, so i just want to confirm if it works before moving on to the actual project: ESP8266 Web Server using SPIFFS with Arduino IDE (NodeMCU) | Random Nerd Tutorials
Make sure you're using the latest version of the Arduino ESP8266 filesystem uploader plugin:
The sketch is not what is uploaded to SPIFFS by the ESP8266 Sketch Data Upload, rather it is the contents of a folder named data in the same folder as the sketch. Is that what you are trying to do ?
pert:
esptool: error: unrecognized arguments: --end · Issue #6864 · esp8266/Arduino · GitHub
I previously downloaded ESP8266FS-0.4.0.zip from: Releases · esp8266/arduino-esp8266fs-plugin · GitHub but i will try with the latest one: ESP8266FS-0.5.0.zip
UKHeliBob:
Yes.
After updating to the latest version, it seemed to work.
esptool.py v2.8
Serial port /dev/ttyUSB0
Connecting........_____....._
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 5c:cf:7f:c2:d5:6d
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 1MB
Compressed 65536 bytes to 226...
Writing at 0x000eb000... (100 %)
Wrote 65536 bytes (226 compressed) at 0x000eb000 in 0.0 seconds (effective 16272.7 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
But then i uploaded this sketch to check if the file was actually saved into the ESP8266 filesystem:
#include "FS.h"
  if(!SPIFFS.begin()){
    Serial.println("An Error has occurred while mounting SPIFFS");
    return;
  File file = SPIFFS.open("/test_example.txt", "r");
  if(!file){
    Serial.println("Failed to open file for reading");
    return;
  Serial.println("File Content:");
  while(file.available()){
    Serial.write(file.read());
  file.close();
And in the Serial Monitor, i got this:
My guess is that the text file found in the data folder somehow did not upload correctly or maybe the sketch did not read the text file??
I just gave it a try and it works as expected for me. I am using an ESP8266 board with 4 MB flash, so it's not an exact reproduction of your setup.
Make sure /home/user/Arduino/Introducing_SPIFFS/data/test_example.txt is really named test_example.txt. I don't remember if this is ever a problem on Linux, but on Windows, the file manager hides file extensions by default, so it's easy to accidentally name the file test_example.txt.txt.
Make sure you have Tools > Erase Flash set to "Only Sketch".
pert:
I am a new user of Linux and i'm using Ubuntu 19.04. To create a new text file, i opened the Text Editor program and typed in some text and saved it into the data folder. I assumed that the .txt extension would be there and i thought it was hidden by default. I was wrong. I logged into a Windows PC and created a new text file there and then transferred it over to my Linux machine into the data folder. The text file created in Linux was called test_example and the one created in Windows has the filename test_example.txt
From Serial Monitor:
20:28:15.198 -> File Content:
20:28:15.198 -> This is sample text to test ESP8266 filesystem
It finally works! :slight_smile:
I'm glad to hear it's working now. Enjoy!
Per
