Esp-01s Relay via firebase
Esp-01s Relay module need to control firebase, pls need to code
thanks..
Need to code
how to turn on & off relay through firebase with esp 01
Need to code esp 01
for a start have a look at ESP01/01S RELAY MODULE TUTORIAL which switches a relay ON/OFF via a web page
possibly modify the to control the relay via firebase?
Need to arduino ide code
I have merged your cross-posts @wruwaniot.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
in the Relay Module Tutorial linked in post #5 there is sample code in Step 3: Uploading the Code
thanks...
i need to add firebase cloud control
i try this code but can't used ESP-01
like this project
what is your problem with firebase on the ESP-01?
if you do a web search for esp 01 firebase you will get plenty of links
i try google can't find esp 01
i try this can't work
112.txt (4.4 KB)
if i google esp 01 firebase I get plenty of links, e.g. connecting-esp8266-to-firebase-to-send-receive-data
what happens when you run the 112.txt program of post #11? upload serial monitor output?
