ESP-07 external antenna - small cap ?
Hello falks, I've found nothing regarding the external antenna of the ESP-07S
My question is:
do I have to remove the small cap you see on the photo ?
I've read on google, that if this is not removed, than there could be an interfearence which could result in a bad connection.
Unbenannt
That is probably a zero Ohm resistor. You can connect only one antenna at a time (the white bar is the default ceramic antenna).
okay, but if I wanna use the external antenna only, than what should I do ?
Remove the zero Ohm resistor, as already recommended.
okay thanks man.
