ESP 32 16 channel relay control I can't because there is only a 4-channel code. I need an Arduino code written with 16 channels on the internet. I am waiting for your urgent help
Hi, @cemalaltun_esp32
Welcome to the forum.
Can you please post the 4 channel code?
Does it work?
Do you have a 16 channel relay module?
If so please post a link to data/specs.
Thanks.. Tom..
What are you stuck with? It should not be too difficult to expand the code to 16 relays but it depends on the board that you have. Are you indeed using an Arduin Nano ESP32 or a generic ESP32? If the latter, which one exactly?
can't you give it a try yourself and post your ideas / describe what's not working?
welcome to the arduino-forum.
Maybe You have chosen these words "need" and "urgent" because your english vocabulary is limited.
The words "need" and "urgent" in this context sound pretty selfish and egoistic.
This maybe was not your intention but it sounds this way.
All the help here is voluntary and free of any charge.
So you can increase the probability to get helpful answers of you use pollite words and if you show own effort.
For the "urgent" help. You yourself can speed up finishing this project
I'm pretty sure that you agree and will follow the way how to solve your problem mimimum 200 minutes faster.
This requires to invest 20 minutes of your precious time to read how to speedup solving your problems.
Directly after registering you got presented informations how to speed up solving your problem.
You should really read it.
best regards Stefan
x
Take the proper 4-channel code you found and adopt it to 16 channels.
You just need to add the other 12 pins to the array with the existing 4 pins.
If it is urgent, you should start immediately.
Have you got the 4 channel code working on 4 of the relays?
Tom..
