I am using ESP32 Wroom to run a wheel robot, i want to program it such that every time the robot stops (I am hardcoding the movement of the robot, it'll stop for 4 secs after it travels for 6 seconds), my esp32 wroom sends a message to my esp32 cam and it should capture image and send it to cloud.
most part is done except the communication between the microcontrollers and i am finding it difficult to complete.
I already tried the solution for communication between esp 32 and esp 32 cam given in the forum, but i am encountering many issues.
it would be helpful if i can get an example where you automatically send a message from esp32 wroom and the esp 32 cam would flash led for a second.
I've been sitting on this for days with almost no progress, any help would be appreciated
Welcome to the forum..
How this would proceed depends on distance between boards..
If they are side by side, tie a gpio line between them and it's a simple button press..
Further apart, consider UDP, it can be a quick trigger as it does not need to connect..
here's a UDP sender demo for esp32 I did a bit ago.. UDP Receive
There's also a sender in that git as well as a cam project that i'm currently working..
might find some ideas in there..
I dont mind if you want to make a scene out of this sir
But thanks anyway.
high priority for me because my distinction depends on this project and the deadline is soon, hope you'll have a nice day.
