webpage is not reach
code is fine and also esp32 cam module perfectly connected to the net, but web page is not reach from given IP. what can be the problem
Only you know since you didn't read the sticky post at the top of this form and then post your code.
If you don't share code/schematics, nobody can share solutions.
esp 32 cam basic example i used
"but web page is not reach from given IP. what can be the problem"
So what is the IP you're trying to reach, and how are you trying to reach that IP?
madhawapolkotuwa:
Most people here will have no idea what that is and no intention of wasting their time to find out. You need to post the program to make it as easy as possible for people to help you.
...R
"esp 32 cam basic example i used"
To put your code in a code box, use the </> icon in the far left of the post tool bar and paste your code between the two bracket sets that appear.
To go back and put your code in a code box, in the bottom right of your post, select "more" and click modify. When the modify post opens, high light your code and click the </> in the far left of the post tool bar. This will put you code in code brackets. Then save the changes.
