Good evening,
I have write this code with chat gpt and a bit of kwowlege :
```cpp
#include <Arduino.h>
#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebSrv.h>
#include <TimeLib.h>
#include <WiFiUdp.h>
#include <NTPClient.h>
#define MOTOR_PIN_DIR 16
#define MOTOR_PIN_PWM 17
#define LIMIT_SWITCH_PIN1 18
#define LIMIT_SWITCH_PIN2 19
const char* ssid = "";
const char* password = "";
AsyncWebServer server(80);
AsyncWebSocket ws("/ws");
const char* htmlHomePage PROGMEM = R"HTMLHOMEPAGE(
<!DOCTYPE html>
<html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1">
<style>
body {
background-color: white;
padding: 10px;
h1, h2 {
color: teal;
text-align: center;
.clock-container {
display: flex;
justify-content: center;
align-items: center;
margin-bottom: 20px;
.clock {
background-color: teal;
color: white;
font-size: 20px;
padding: 10px 20px;
border-radius: 5px;
box-shadow: 2px 2px 5px rgba(0, 0, 0, 0.2);
.btn-container {
display: flex;
justify-content: space-around;
margin-top: 20px;
.btn {
background-color: black;
color: white;
font-size: 18px;
padding: 10px 20px;
border-radius: 5px;
.noselect {
-webkit-touch-callout: none; /* iOS Safari */
-webkit-user-select: none; /* Safari */
-khtml-user-select: none; /* Konqueror HTML */
-moz-user-select: none; /* Firefox */
-ms-user-select: none; /* Internet Explorer/Edge */
user-select: none; /* Non-prefixed version, currently supported by Chrome and Opera */
</style>
</head>
<body class="noselect">
<h1>Finestra casetta</h1>
<h2>Usare con maniera</h2>
<div class="clock-container">
<div class="clock">
<label for="startTime1">Orario di apertura:</label>
<br>
<input type="time" id="startTime1">
</div>
</div>
<div class="clock">
<label for="startTime2">Orario di chiusura:</label>
<br>
<input type="time" id="startTime2">
</div>
</div>
<div class="btn-container">
<button class="btn" ontouchstart="openWindow()" ontouchend="stopAction()">Apri</button>
<button class="btn" ontouchstart="closeWindow()" ontouchend="stopAction()">Chiudi</button>
</div>
<script>
var webSocketUrl = "ws:\/\/" + window.location.hostname + "/ws";
var websocket;
function initWebSocket() {
websocket = new WebSocket(webSocketUrl);
websocket.onopen = function (event) {};
websocket.onclose = function (event) {
setTimeout(initWebSocket, 2000);
websocket.onmessage = function (event) {
if (event.data === "stop") {
stopAction();
// Aggiunta delle seguenti funzioni
function openWindow() {
var startTime1 = document.getElementById("startTime1").value;
webStartTime1 = startTime1;
websocket.send("1#" + startTime1);
function closeWindow() {
var startTime2 = document.getElementById("startTime2").value;
webStartTime2 = startTime2;
websocket.send("2#" + startTime2);
function stopAction() {
websocket.send("0");
window.onload = initWebSocket;
</script>
)HTMLHOMEPAGE";
String webStartTime1 = "";
String webStartTime2 = "";
int motor1StartHour = 8;
int motor1StartMinute = 0;
int motor2StartHour = 17;
int motor2StartMinute = 30;
int velocita_motore = 100;
bool limitSwitch1State = false;
bool limitSwitch2State = false;
bool windowMoving = false;
int windowDirection = 0; // 0: Stop, 1: Opening, 2: Closing
void rotateMotor(int motorDirection) {
if (motorDirection == 1) {
digitalWrite(MOTOR_PIN_DIR, HIGH);
analogWrite(MOTOR_PIN_PWM, velocita_motore);
} else if (motorDirection == 2) {
digitalWrite(MOTOR_PIN_DIR, LOW);
analogWrite(MOTOR_PIN_PWM, 0);
void processWindowAction(String action, int startHour, int startMinute) {
if (action == "1") {
motor1StartHour = webStartTime1.substring(0, 2).toInt();
motor1StartMinute = webStartTime1.substring(3).toInt();
rotateMotor(1); // Apri la finestra
windowMoving = true;
windowDirection = 1;
} else if (action == "2") {
motor2StartHour = webStartTime2.substring(0, 2).toInt();
motor2StartMinute = webStartTime2.substring(3).toInt();
rotateMotor(2); // Chiudi la finestra
windowDirection = 2;
rotateMotor(0); // Ferma il motore
void handleRoot(AsyncWebServerRequest* request) {
request->send_P(200, "text/html", htmlHomePage);
void handleNotFound(AsyncWebServerRequest* request) {
request->send(404, "text/plain", "File Not Found");
void onWebSocketEvent(AsyncWebSocket* server,
AsyncWebSocketClient* client,
AwsEventType type,
void* arg,
uint8_t* data,
size_t len) {
switch (type) {
case WS_EVT_CONNECT:
Serial.printf("WebSocket client #%u connected from %s\n", client->id(), client->remoteIP().toString().c_str());
case WS_EVT_DISCONNECT:
Serial.printf("WebSocket client #%u disconnected\n", client->id());
processWindowAction("0", 0, 0);
case WS_EVT_DATA:
AwsFrameInfo* info;
info = (AwsFrameInfo*)arg;
if (info->final && info->index == 0 && info->len == len && info->opcode == WS_TEXT) {
std::string myData = "";
myData.assign((char*)data, len);
String action = String(myData.c_str()).substring(0, 1);
String startTime = String(myData.c_str()).substring(2);
int startHour = startTime.substring(0, 2).toInt();
int startMinute = startTime.substring(3).toInt();
processWindowAction(action, startHour, startMinute);
pinMode(MOTOR_PIN_DIR, OUTPUT);
pinMode(MOTOR_PIN_PWM, OUTPUT);
pinMode(LIMIT_SWITCH_PIN1, INPUT_PULLUP);
pinMode(LIMIT_SWITCH_PIN2, INPUT_PULLUP);
WiFi.softAP(ssid, password);
IPAddress IP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(IP);
server.on("/", HTTP_GET, handleRoot);
server.onNotFound(handleNotFound);
ws.onEvent(onWebSocketEvent);
server.addHandler(&ws);
server.begin();
ws.cleanupClients();
int currentHour = hour();
int currentMinute = minute();
if (currentHour == motor1StartHour && currentMinute == motor1StartMinute && windowMoving && windowDirection == 1) {
} else if (currentHour == motor2StartHour && currentMinute == motor2StartMinute && windowMoving && windowDirection == 2) {
bool newLimitSwitch1State = digitalRead(LIMIT_SWITCH_PIN1);
bool newLimitSwitch2State = digitalRead(LIMIT_SWITCH_PIN2);
if (newLimitSwitch1State != limitSwitch1State && newLimitSwitch1State == HIGH) {
if (windowMoving && windowDirection == 1) {
rotateMotor(2); // Inverti la direzione del motore
if (newLimitSwitch2State != limitSwitch2State && newLimitSwitch2State == HIGH) {
if (windowMoving && windowDirection == 2) {
rotateMotor(1); // Inverti la direzione del motore
limitSwitch1State = newLimitSwitch1State;
limitSwitch2State = newLimitSwitch2State;
delay(100);
The web interfaces is good, i like to add some features but it's ok, why the schedule does not work? If Ipress one button dc motor goes forward and backward but if Iuse the time i doesn't work.
the connection are correct because with button it work so the problem is in the code.
Thank you so much
