hello,
I have purchased the ESP32 development board "ESP32-D0WDQ6 Development Board - with Wi-Fi and Bluetooth" at TinyTronics
However I can't upload anything on it. I get the attached error. I have tried several board configuration (Dev module, Dev module S3, C3, Dev module WROOM, etc.) with always the same error. Tried also different cables.
Arduino: 1.8.19 (Mac OS X), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None"
Sketch uses 202641 bytes (15%) of program storage space. Maximum is 1310720 bytes.
Global variables use 16004 bytes (4%) of dynamic memory, leaving 311676 bytes for local variables. Maximum is 327680 bytes.
esptool.py v3.3
Serial port /dev/cu.usbserial-1410
Connecting.....Traceback (most recent call last):
File "esptool.py", line 5387, in <module>
File "esptool.py", line 5380, in _main
File "esptool.py", line 4802, in main
File "esptool.py", line 1056, in flash_set_parameters
File "esptool.py", line 495, in check_command
File "esptool.py", line 468, in command
File "esptool.py", line 413, in read
StopIteration
[6660] Failed to execute script 'esptool' due to unhandled exception!
Chip is ESP32-D0WDQ6-V3 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 94:b9:7e:cd:ae:70
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
An error occurred while uploading the sketch
option enabled in File -> Preferences.
Any ideas what to do? Below are my settings (MAC OS Monterey)
