Hi i am trying to use SDMMC with Esp Firebeetle 4.0
i am using those pins IO9 IO10 IO6 IO7 IO8 IO11
i am following this tutorial
i changed pins in definition to
int clk = 6;
int cmd = 11;
int d0 = 7;
int d1 = 8;
int d2 = 9;
int d3 = 10;
but unfortunetly its not working
ELF file SHA256: 0000000000000000
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1412
load:0x40078000,len:13400
load:0x40080400,len:3672
entry 0x400805f8
E (56) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
E (57) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
assertion "xQueue" failed: file "../esp-idf/components/freertos/queue.c", line 1940, function: uxQueueMessagesWaiting
abort() was called at PC 0x400eadd7 on core 1
Backtrace:0x400d7e6d:0x3ffb25a00x40088db9:0x3ffb25c0 0x4008ebb1:0x3ffb25e0 0x400eadd7:0x3ffb2660 0x40089f99:0x3ffb2690 0x400dd2cf:0x3ffb26b0 0x400db8e9:0x3ffb26e0 0x400dba52:0x3ffb2720 0x400e4db9:0x3ffb2740 0x400d30ad:0x3ffb2770 0x400d2242:0x3ffb27f0 0x400d4687:0x3ffb2820
Have you any advices?
