ESP 32 ST7735 Display Red & Blue color Swapped
Hardware Used: -
ESP 32 DEVKIT V1 - Processor
ST7735 - Display
I want to load a simple image in the display.
I am making use of just TFT_eSPI library, Push image function.
My ultimate goal is to run a GIF using that Function.
But as I am loading the image it is full of grains
code-
//#include <Adafruit_GFX.h>    // Core graphics library
//#include <XTronical_ST7735.h> // Hardware-specific library
#include <SPI.h>
#include <AnimatedGIF.h>
#include "../test_images/badgers.h"
#include <TFT_eSPI.h>
#include "welcome.h"
#include "Anime00.h"
// set up pins we are going to use to talk to the screen
#define TFT_DC     2       // register select (stands for Data Control perhaps!)
#define TFT_RST   4         // Display reset pin, you can also connect this to the ESP32 reset
                            // in which case, set this #define pin to -1!
#define TFT_CS   5       // Display enable (Chip select), if not enabled will not talk on SPI bus
#define TFT_SCLK   18
#define TFT_MOSI   23
// initialise the routine to talk to this display with these pin connections (as we've missed off
// TFT_SCLK and TFT_MOSI the routine presumes we are using hardware SPI and internally uses 13 and 11
TFT_eSPI tft = TFT_eSPI();
const int pwmFreq = 5000;
const int pwmResolution = 8;
const int pwmLedChannelTFT = 5;
    tft.begin();
    tft.setRotation(0);
    tft.fillScreen(TFT_BLACK);
//tft.setSwapBytes(true);
//tft.invertDisplay(true);
   ledcSetup(pwmLedChannelTFT, pwmFreq, pwmResolution);
  ledcAttachPin(17, pwmLedChannelTFT);
  ledcWrite(pwmLedChannelTFT, 80);
 //for(int i=0;i<9;i++)
  //  for(int i=0;i<12;i++){
  //   tft.pushImage(0,0,128,128,Animes[i]);
 tft.pushImage(0,0,128,128,welcome);
  //     delay(80);}
//tft.fillScreen(TFT_RED);
//delay(1000);
//delay(1000);
//tft.fillScreen(TFT_BLUE);
//delay(1000);
and image that it gives is as follow
next to clear the grains I have used , tft.setSwapBytes(true); function.
It gave me grain less image, but now the red and blue color is swaped.
and now it looks like this -
The image that is originally supposed to load is this.
frame_00_delay-0.1s
Is there any way to fix this?
The array of colors used in the program are in R5G6B6 format in 16 bit.
