I am currently working on a project in which I have to replace communication method between an android application and an Arduino Due Device from Bluetooth to Wi-Fi. Thus my choice for Wi-Fi communication is ESP8266. As a start, I want to be able to create a HTML webpage with 4 buttons and have each button send an array of integers to the Arduino Due. I have been trying to search for some example projects where an ESP 8266 and Arduino Due are used to transfer data back and forth from a webpage. Is there any example code out there in order to connect the ESP8266 to Arduino Due and also create a webpage to transfer data to my Arduino Due through ESP8266. Most examples use Arduino Uno and I am not sure how I can modify the codes to work with Due.
It should be rather simple to modify codes working with a UNO to work with a DUE.
There are some tutorials for ESP8266 and DUE though:
BTW, there is a 100% compatible DUE board with a special header to connect with an ESP8266 (plus 30 I/O exposed pins + an SD card), the DUE XPRO:
DUE XPRO compatible Arduino DUE (+ 30 I/O):
https://robotdyn.com/due-xpro-arm-cortex-atsam3x8ea-au-98-i-o-sd-reader-rgb-led-esp-01-socket-a13af1a7-9cbc-11e9-9111-901b0ebb3621.html
