ESP 8266 & Google OAuth
Looking for some help in implementing a version of this project. I'm using an ESP8266 as a webserver for the simple page to generate a code for OAuth to approve the device and generate a Refresh Token and Access Token.
Everything works until I get to the actual point of connecting with Google servers. I'm using <WiFiClientSecure.h> but this always fails and I don't know why.
WiFiClientSecure client
if(!client.connect("https://accounts.google.com/o/oauth2/v2/auth", 443)){
  Serial.println(F("Connection to google server failed"));
} else{
  Serial.println("connected to google");
I have seen examples using client.connect, httpsClient.connect, and client_tcp.connect. none of those work. I have also tried all these connection methods with all the different URLs in the documentation given the various methods/devices including
Hoping there is someone who has been able to connect an ESP (orArduino) to Google OAuth and can help. Do I need another library for a an https connection (BearSSL)? Once I connect, do I need a certificate (google documentation doesn't indicate a certificate but not sure if that's just part of an https connection)? The aim is to connect to the Google Drive scope (https://www.googleapis.com/auth/drive.file) to upload pictures to a dedicated folder.
@travisstdenis Please edit the question to include a minimal, reproducible demonstrating the problem. In this case that should be very simple, just the code to connect to wifi and set up and try to connect using client. We don't know how you defined client ... people trying to help could guess and ask questions but it's much easier if you simply provide the actual code.
