esp and ports
I have problem with ports in my esp8622, and i dont know why.
In station mode or connecting to a wifi y only can make tcp server with port 80.
yesterday work but now not, and i dont know what y change. i restart de firmware and nothing.
someone have idea?
ty.
void setup(void)
  mySerial.begin(9600);
    Serial.print("setup begin\r\n");
    Serial.print("FW Version:");
    Serial.println(wifi.getVersion().c_str());
    if (wifi.setOprToStationSoftAP()) {
        Serial.print("to station + softap ok\r\n");
        Serial.print("to station + softap err\r\n");
    if (wifi.joinAP(CONNECT_NAME, CONNECT_PASSWORD)) {
        Serial.print("Join AP success\r\n");
        Serial.print("IP: ");
        Serial.println(wifi.getLocalIP().c_str());
        Serial.print("Join AP failure\r\n");
    if (wifi.setSoftAPParam(NAME, PASSWORD, CHNL, ENCRYPT)) {
        Serial.print("Create AP success\r\n");
        Serial.print("Create AP failure\r\n");
    if (wifi.enableMUX()) {
        Serial.print("multiple ok\r\n");
        Serial.print("multiple err\r\n");
    if (wifi.startTCPServer(PORT)) {
        Serial.print("start tcp server ok\r\n");
        Serial.print("start tcp server err\r\n");
    if (wifi.setTCPServerTimeout(TIMEOUT)) {
        Serial.print("set tcp server timout ok\r\n");
        Serial.print("set tcp server timout err\r\n");
 pinMode(M_SPEED, OUTPUT);
 pinMode(M_BEHIND,OUTPUT);
 pinMode(M_FRONT,OUTPUT);
 velocity(0);
 myServo.attach(7);
 myServo.write(93);//mid
    Serial.print("setup end\r\n");
pd: library--->GitHub - itead/ITEADLIB_Arduino_WeeESP8266: An easy-to-use Arduino ESP8266 library besed on AT firmware.
You posted part of your code. I'll post part of the answer.
You need to ...
#include "ESP8266.h"
#include "SoftwareSerial.h"
#include "Servo.h"
#define CONNECT_NAME "DELPALACIO"
#define CONNECT_PASSWORD "0000000000"
#define NAME "WifCar"
#define PASSWORD "0000000000"
#define CHNL 7
#define ENCRYPT 3 //0 is encryption type like 0 = Open, 2 =WPA_PSK, 3 = WPA2_PSK, 4 = WPA_WPA2_PSK
#define PORT 80
#define TIMEOUT 0
#define M_BEHIND 4
#define M_FRONT 5
#define M_SPEED 6
SoftwareSerial mySerial(3, 2); /* RX:D3, TX:D2 */
ESP8266 wifi(mySerial);
Servo myServo;
String command;
String value;
void setup(void)
 velocity(0);
 myServo.attach(7);
void loop(void)
    uint8_t buffer[128] = {0};
    uint8_t mux_id;
    uint32_t len = wifi.recv(&mux_id, buffer, sizeof(buffer), 100);
    String msg;
    if (len > 0) {
        for(uint32_t i = 0; i < len; i++) {
            if ((char)buffer[i] != ';')
              msg+= (char)buffer[i];
              msg+=';'; //adding ; for split
              command = getStringPartByNr(msg, '=', 0);
              value = getStringPartByNr(msg, '=', 1);
              Serial.print("Msg["+msg+"]:: "+command+" "+value+"\r\n");
               if(command.equalsIgnoreCase("MAR"))
                gear(value);
               else if(command.equalsIgnoreCase("VEL"))
                velocity(value.toInt());
               else if(command.equalsIgnoreCase("ROT"))
                revolution(value.toInt());
               msg="";  //clear msg
void gear(String g){
      if(g.equalsIgnoreCase("del"))
       //Serial.print("Front\r\n");
       digitalWrite(M_BEHIND,LOW);
       digitalWrite(M_FRONT,HIGH);
     else if(g.equalsIgnoreCase("tra"))
       //Serial.print("Behind\r\n");
       digitalWrite(M_BEHIND,HIGH);
       digitalWrite(M_FRONT,LOW);
void velocity(int v){
  analogWrite(M_SPEED, v);
  //Serial.print("Speed: "+String(v)+"\r\n");
void revolution(int r){
    int maped =map(r,-10, 10, 125, 0); //map servo and acelerometer values
    myServo.write(maped);
    //Serial.print("Servo: "+String(maped)+"\r\n");
String getStringPartByNr(String data, char separator, int index)
    // spliting a string and return the part nr index
    // split by separator
    int stringData = 0;        //variable to count data part nr
    String dataPart = "";      //variable to hole the return text
    for(int i = 0; i<data.length()-1; i++) {    //Walk through the text one letter at a time
      if(data[i]==separator) {
        //Count the number of times separator character appears in the text
        stringData++;
      }else if(stringData==index) {
        //get the text when separator is the rignt one
        dataPart.concat(data[i]);
      }else if(stringData>index) {
        //return text and stop if the next separator appears - to save CPU-time
        return dataPart;
    //return text if this is the last part
    return dataPart;
Your code doesn't demonstrate trying to create a TCP server connected to a different port.
Yesterday, what worked? Connecting to a different port? On the same server? From the same location?
yes, with port 400, with same server and same location
Here is a photo with the problem:
http://subefotos.com/ver/?bcfa3a2e7f1561af7255c4a83dbb2c72o.png#codigos
