Have anyone tried to use the SC031GS camera with the esp_camera.h arduino library?
I always get the following camera error:
E (23) camera: Camera probe failed with error 0x105(ESP_ERR_NOT_FOUND)
Camera init failed with error 0x105Camera ERROR!
Camera capture failed.
I´m using the following configuration:
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sccb_sda = SIOD_GPIO_NUM;
config.pin_sccb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 10000000;
config.frame_size = FRAMESIZE_QQVGA; //NEW ou FRAMESIZE_VGA
config.pixel_format = PIXFORMAT_GRAYSCALE; // for streaming NEW
config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
config.fb_location = CAMERA_FB_IN_PSRAM;
//config.jpeg_quality = 2;
config.fb_count = 1;
config.frame_size = FRAMESIZE_VGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA //HEHE
config.grab_mode = CAMERA_GRAB_LATEST;
config.pixel_format = PIXFORMAT_RAW;
Other cameras like OV2460 work normally with jpeg enabled, but the SC031GS doesn't even is detected.
Anyone can help me please?
Thanks a lot!!
