I had a sketch (nearly) working on my Adafruit Huzzah module; found a (known) issue with wifi reconnect so tried to change the esp8266 core (v 2.4.0) to an earlier version (using Boards Manager in the Arduino IDE).
But now my sketch won't compile at all: "Board huzzah (platform esp8266, package esp8266) is unknown". Tried changing back to core version 2.4.0 but same problem.
What have I done wrong?
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\chris\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\chris\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\chris\Documents\Arduino\libraries -fqbn=esp8266:esp8266:huzzah:CpuFrequency=80,FlashSize=4M3M,LwIPVariant=v2mss536,Debug=Disabled,DebugLevel=None____,UploadSpeed=115200 -ide-version=10801 -build-path C:\Users\chris\AppData\Local\Temp\arduino_build_651299 -warnings=default -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\chris\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.2.0 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\chris\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.esptool.path=C:\Users\chris\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.12 -verbose C:\Users\chris\Documents\Arduino\esp-logger\esp-logger.ino
Error compiling for board Adafruit HUZZAH ESP8266.
