ESP: "Could not parse error, connection failed"
I found a code for ESP, which should track in real time what I'm currently listening to in spotify and display information about the song currently playing. In order for this code to work, I need another code that will give me a token. The trouble is that the code that should display the token for me gives the following:
Connected to NewHome
IP address: 192.168.1.248
MDNS responder started
HTTP server started
grant_type=authorization_code&code=AQAxI7L0C2F__5pW0X8ugFnVsXiaS00QoyX4klno4ePF1DePUBjaJ2FEMPP8nTV8m2gfd6c8aVODUfoAPzNPOMZ8s4YY5Q-1YkSbkKDLyQ-6qVzIHKHailEfR5CFeNCNIxxavmaM-YQs-hZnPPSMQ33U9sicpmgLHTCwNYiMxc6uKhERy1Vd9mG0NPlEtVyg4fwenPps1eCqVSlMzsNoZ7kJDcAyDPZs664mt7fAp2FqRNC6lcB8ZA&redirect_uri=http%3A%2F%2F192.168.1.248%2Fcallback%2F&client_id=bad57701506146ef8090a2fcabfbb7e2&client_secret=c1f1c44083e14d5fb5f11522c12601dd
accounts.spotify.com
Connection failed
status Code-1
What is the reason for this error and how to fix it?
here is a code
#if defined(ESP8266)
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#elif defined(ESP32)
#include <WiFi.h>
#include <WebServer.h>
#include <ESPmDNS.h>
#endif
#include <WiFiClient.h>
#include <WiFiClientSecure.h>
// Additional Libraries - each one of these will need to be installed.
#include <SpotifyArduino.h>
// Library for connecting to the Spotify API
// Install from Github
// https://github.com/witnessmenow/spotify-api-arduino
// including a "spotify_server_cert" variable
// header is included as part of the SpotifyArduino libary
#include <SpotifyArduinoCert.h>
#include <ArduinoJson.h>
// Library used for parsing Json from the API responses
// Search for "Arduino Json" in the Arduino Library manager
// https://github.com/bblanchon/ArduinoJson
//------- Replace the following! ------
char ssid[] = "xxx";         // your network SSID (name)
char password[] = "xxx"; // your network password
char clientId[] = "xxx";     // Your client ID of your spotify APP
char clientSecret[] = "xxx"; // Your client Secret of your spotify APP (Do Not share this!)
char scope[] = "user-read-playback-state%20user-modify-playback-state";
#define USE_IP_ADDRESS 1 //comment this out if you want to use MDNS
#ifdef USE_IP_ADDRESS
char callbackURItemplate[] = "%s%s%s";
char callbackURIProtocol[] = "http%3A%2F%2F"; // "http://"
char callbackURIAddress[] = "%2Fcallback%2F"; // "/callback/"
char callbackURI[100];
#else
char callbackURI[] = "http%3A%2F%2Farduino.local%2Fcallback%2F";
#endif
ESP8266WebServer server(80);
#endif
WiFiClientSecure client;
SpotifyArduino spotify(client, clientId, clientSecret);
const char *webpageTemplate =
    R"(
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no" />
  </head>
  <body>
    <div>
     <a href="https://accounts.spotify.com/authorize?client_id=%s&response_type=code&redirect_uri=%s&scope=%s">spotify Auth</a>
    </div>
  </body>
</html>
void handleRoot()
  char webpage[800];
  sprintf(webpage, webpageTemplate, clientId, callbackURI, scope);
  server.send(200, "text/html", webpage);
void handleCallback()
  String code = "";
  const char *refreshToken = NULL;
  for (uint8_t i = 0; i < server.args(); i++)
    if (server.argName(i) == "code")
      code = server.arg(i);
      refreshToken = spotify.requestAccessTokens(code.c_str(), callbackURI);
  if (refreshToken != NULL)
    server.send(200, "text/plain", refreshToken);
    server.send(404, "text/plain", "Failed to load token, check serial monitor");
void handleNotFound()
  String message = "File Not Found\n\n";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET) ? "GET" : "POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
    message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
  Serial.print(message);
  server.send(404, "text/plain", message);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  Serial.println("");
  // Wait for connection
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  IPAddress ipAddress = WiFi.localIP();
  Serial.println(ipAddress);
  if (MDNS.begin("arduino"))
    Serial.println("MDNS responder started");
  // Handle HTTPS Verification
  client.setFingerprint(SPOTIFY_FINGERPRINT); // These expire every few months
  client.setCACert(spotify_server_cert);
#endif
  // ... or don't!
  //client.setInsecure();
  // If you want to enable some extra debugging
  // uncomment the "#define SPOTIFY_DEBUG" in ArduinoSpotify.h
  // Building up callback URL using IP address.
  sprintf(callbackURI, callbackURItemplate, callbackURIProtocol, ipAddress.toString().c_str(), callbackURIAddress);
#endif
  server.on("/", handleRoot);
  server.on("/callback/", handleCallback);
  server.onNotFound(handleNotFound);
  server.begin();
  Serial.println("HTTP server started");
  MDNS.update();
#endif
  server.handleClient();
Your topic was MOVED to its current forum category as it is more suitable than the original
What made you think that it had anything to do with Covid ?
sorry it was an accident
