ESP Crash on connection to SMTP Server
So I’ve been working on this for a few hours integrating the code into my sketch. Unfortunayley, it crashes.
The line that I figure it crashes on is “if (!clients.connect(smtp_server, smtp_port)) {” where smtp_server is a String and smtp_port is an int.
The function here:
bool Gsender_Send() {
  DEBUG_AM("Connecting to :");
  DEBUG_AM(smtp_server);
    _error = "Could not connect to mail server";
    strcat(_error, csmtp_server);
    strcat(_error, ":");
    strcat(_error, csmtp_port);
   DEBUG_AM(_error);
    return false;
  DEBUG_AM("220");
  if (!Gsender_AwaitSMTPResponse(clients, "220", smtpTimeOut)) {
    _error = "Connection Error";
     DEBUG_AM(_error);
    return false;
  DEBUG_AM("HELO friend:");
  clients.println("HELO friend");
  if (!Gsender_AwaitSMTPResponse(clients, "250", smtpTimeOut)) {
    _error = "identification error";
     DEBUG_AM(_error);
    return false;
  DEBUG_AM("AUTH LOGIN:");
  clients.println("AUTH LOGIN");
  Gsender_AwaitSMTPResponse(clients, "334", smtpTimeOut);
  DEBUG_AM("smtpUserID:");
  DEBUG_AM(smtpUserID);
  clients.println(encode64(csmtpUserID));
  DEBUG_AM("smtp_pass:");
  DEBUG_AM(smtp_pass);
  clients.println(encode64(csmtp_pass));
  if (!Gsender_AwaitSMTPResponse(clients, "235", smtpTimeOut)) {
    _error = "SMTP AUTH error";
    return false;
  String mailFrom = "MAIL FROM: <" + String(smtpFrom) + '>';
  DEBUG_AM(smtpFrom);
  clients.println(smtpFrom);
  Gsender_AwaitSMTPResponse(clients, "250", smtpTimeOut);
  String rcpt = "RCPT TO: <" + smtpTo + '>';
  DEBUG_AM(smtpTo);
  clients.println(smtpTo);
  DEBUG_AM("DATA:");
  clients.println("DATA");
  if (!Gsender_AwaitSMTPResponse(clients, "354", smtpTimeOut)) {
    _error = "SMTP DATA error";
    return false;
  clients.println("From: <" + smtpFrom + '>');
  clients.println("To: <" + smtpTo + '>');
  clients.print("Subject: ");
  clients.println(subject);
  clients.println("Mime-Version: 1.0");
  clients.println("Content-Type: text/html; charset=\"UTF-8\"");
  clients.println("Content-Transfer-Encoding: 7bit");
  clients.println();
  clients.println(body);
  clients.println(".");
    _error = "Sending message error";
    return false;
  clients.println("QUIT");
  if (!Gsender_AwaitSMTPResponse(clients, "221", smtpTimeOut)) {
    _error = "SMTP QUIT error";
    return false;
  return true;
The Stack Decode:
Decoding stack results
0x40208f9c: HardwareSerial::write(unsigned char const*, unsigned int) at C:\Users\matt\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/HardwareSerial.h line 174
0x401008e1: realloc at C:\Users\matt\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266\umm_malloc\umm_malloc.c line 1504
0x402096c3: String::changeBuffer(unsigned int) at C:\Users\matt\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266\WString.cpp line 156
0x40100a44: free at C:\Users\matt\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266\umm_malloc\umm_malloc.c line 1760
0x40209235: Print::write(char const*) at C:\Users\matt\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/Print.h line 60
0x40100600: _umm_free at C:\Users\matt\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266\umm_malloc\umm_malloc.c line 1300
0x40209680: String::invalidate() at C:\Users\matt\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266\WString.cpp line 141
0x4020398d: sendEmail(String, String) at C:\Users\matt\Documents\Arduino\node9-9/node9-9.ino line 176
0x40209758: String::copy(char const*, unsigned int) at C:\Users\matt\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266\WString.cpp line 182
0x40209844: String::operator=(String const&) at C:\Users\matt\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266\WString.cpp line 220
0x40204012: statusReport() at C:\Users\matt\Documents\Arduino\node9-9/node9-9.ino line 428
0x4020421f: setup() at C:\Users\matt\Documents\Arduino\node9-9/node9-9.ino line 141
0x4020a384: loop_wrapper() at C:\Users\matt\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266\core_esp8266_main.cpp line 122
Finally I attached the Whole Sketch.
node9-9.ino (21.9 KB)
   DEBUG_AM(_error);
    return false;
You set _error (a char *) to point to a c-string literal. Then you proceed to strcat a bunch of stuff on the end of that literal. That's trashing memory that you don't own.
gfvalvo:
_error = “Could not connect to mail server”;
    strcat(_error, “:”);
  DEBUG_AM(_error);
    return false;
It’s gone a little further… now crashing with message “Abort Called”.
mattlogue:
It's gone a little further... now crashing with message "Abort Called".
The point is you shouldn't modify "_error". Everything after is irrelevant if you don't fix this first.
I took out modifications to error and it still crashes, but on second connection attempt. Stack decode suggests it stops in wificlientsecure.
mattlogue:
Please post your modified code.
int sendEmail(String subject, String body) {
   return 0; //Suspended untill I figure out crashing...
  Serial.printf("\n STMP User ID: %s", smtpUserID.c_str());
  Serial.printf("\n To address: %s", smtpTo.c_str());
  Serial.printf("\n From address: %s", smtpFrom.c_str());
  Serial.printf("\n Subject: %s", subject.c_str());
  Serial.printf("\n Body: %s", body.c_str());
  //Flood control, only 3 messages per minute
  if (millis() - lastEmailMS > 60000) {
    emailsCount = 0;
  if (emailsCount > 2) {
    Serial.printf("Flood control - email (%s) not sent!\n");
    return 460;
  //If first of three emails, set time
  if (emailsCount == 0) lastEmailMS = millis();
  emailsCount++;
  //End of flood control
  String sendStatus;
  smtp_pass = ep("ATTPass");
  smtpUserID.toCharArray(csmtpUserID, 16);
  smtp_pass.toCharArray(csmtp_pass, 16);
  smtp_server.toCharArray(csmtp_server, 32);
  DEBUG_AM("Sending message to ");
  DEBUG_AM(smtpTo);
  DEBUG_AM(':');
  DEBUG_AM("SUBJECT: ");
  DEBUG_AM(subject);
  DEBUG_AM("   BODY: ");
  DEBUG_AM(body);
  if (Gsender_Send() == true) {
    DEBUG_AM("Message sent successfully.");
    sendStatus = "SENT";
    return 200;
  else {
    DEBUG_AM("Message sending failed. (");
    DEBUG_AM(_error);
    DEBUG_AM(')');
    sendStatus = _error;
  if (sendStatus != "SENT") {
    Serial.printf("Send error: %s", sendStatus.c_str());
    return 470;
  DEBUG_AM(smtp_port);
  clients.connect(smtp_server, smtp_port);
  do {
    DEBUG_AM("Awaiting connection");
    delay(100);
  while (clients._clientConnectedState() < 100);
  long stmpTimeOut = 5000;
  char *response = "";
  String responseString = "";
  long doMS = millis();
  do {
    DEBUG_AM(clients.available());
    responseString = clients.readStringUntil('\n');
    responseString.toCharArray(response, 16);
    if (millis() - doMS > stmpTimeOut) {
      DEBUG_AM("Timed out");
      return false;
    delay(100);
  while (strlen(response) < 2);
  if (response == "220") {
    DEBUG_AM("220 OK");
  else {
    DEBUG_AM(response); return false;
  doMS = millis();
  do {
    while (clients.available()) {
        return false;
  if (response == "250") {
    DEBUG_AM("250 HELO OK");
  else {
  doMS = millis();
  do  {
        return false;
  if (response == "334") {
    DEBUG_AM("334 AUTH OK");
  else {
  doMS = millis();
  do {
        return false;
    DEBUG_AM("334 USERID OK");
  else {
  doMS = millis();
  do {
        return false;
  if (response == "235") {
    DEBUG_AM("235 LOGGED IN OK");
  else {
  DEBUG_AM(smtpFrom);
  doMS = millis();
  do {
        return false;
    DEBUG_AM("250 MAIL FROM OK");
  else {
  DEBUG_AM(smtpTo);
  doMS = millis();
  do {
        return false;
    DEBUG_AM("250 MAIL TO OK");
  else {
  DEBUG_AM("DATA:");
  doMS = millis();
  do {
        return false;
  if (response == "354") {
    DEBUG_AM("354 DATA OK");
  else {
  clients.println();
  doMS = millis();
  do {
        return false;
    DEBUG_AM("250 MESSAGE SENT OK");
  else {
  return true;
Post (attach) the whole code. Really need to see how variables are defined, etc.
I will once I remove a bug I added, it crashes there now and having you help me with that would waste your time and embrass me...
