ESP Daily task with Deep sleep
Hi there
i want to make a battery operated feeder
i am trying to use this library but it doesn't run at specific time and always miss the time
can someone please take a look and see what is messed up ?
i have tried to change lot in deep sleep time but still can't make it work (ESPDailyTaskNTP.cpp)
-replaced 1 by 1000/10000/1000000 in sleep
-changed NTP url / Time Zone
-various hour setting
-diff reset pin
-diff rtc flag
-diff sleep modes
if task time is less then 1 hour after fetching time from NTP (when counter hits 0 or via reset pin) it does the task go back to sleep mode but again after 24 hour their is no task and keep goes on
attaching serial monitor output
Post your code in code tags.
Is the uController a ESP32 or a ESP8266?
Put the images in img tags.
Idahowalker:
sorry forgot to mention its ESP8266 - Lolin D1 mini and NodemcuV3
using same example as in lib for testing purpose with minimal change
OncePerDay example for ESP8266
This routine gets the unixtime from a NTP server and adjusts it to the time zone and the
Middle European summer time if requested
Copyright (c) 2016 Andreas Spiess
V1.1 2016-8-15
char my_SSID[]= "XYZ";  // ssid of your accesspoint
char my_PASSWORD[]= "123";  // password of access point
#include <ESP8266WiFi.h>
#include <ESPDailyTaskNTP.h>
#include <SNTPtime.h>
char SNTP_SERVER[]="ch.pool.ntp.org";
SNTPtime NTPwork(SNTP_SERVER);
#define RESET_PIN D2
ESPDailyTaskNTP dailyTask(12, 0, 1.0, my_SSID, my_PASSWORD, RESET_PIN); // Hour to do the task
  Serial.println();   Serial.println("Start");   Serial.println();
  dailyTask.sleepOneDay();
  // ------------------ put the code for your daily task here -------------------------------
  Serial.println("............ W O R K ...............................");
  NTPwork.setSNTPtime();
  strDateTime _time = NTPwork.getTime(1.0, 1);
  NTPwork.printDateTime(_time);
  Serial.println("i am awake");
  // ----------------------- end of code for your daily task-------------------------------
  // and back to sleep once daily code is done
  dailyTask.backToSleep();
  // sleeping so wont get here
again failed
.........WiFi connected
1587138411
2020-4-17-6 21H 16M 51S
_currentSecs: 76611
_wakeUpSecs: 75120
_secondsToGo: 84909
CHECK   Status: 1, markerFlag: 87, counter: 23, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 22, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 21, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 20, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 19, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 18, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 17, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 16, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 15, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 14, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 13, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 12, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 11, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 10, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 9, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 8, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 7, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 6, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 5, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 4, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 3, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 2, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 1, sleepTime: 3595000000
Start
COUNTING DOWN   Status: 1, markerFlag: 87, counter: 0, sleepTime: 3595000000
Start
COUNTING ZERO  Status: 2, markerFlag: 87, counter: 0, sleepTime: 1000000
Start
1587224307
2020-4-18-7 21H 8M 27S
_currentSecs: 76107
_wakeUpSecs: 75120
_secondsToGo: 85413
