ESP does not name a type
Hello, i am trying to add libarary and running the example code. the library from https://github.com/tuanpmt/espduino. When i running the code i have some error message “ESP does not name a type”
Here the sample code :
 * \file
 *       ESP8266 MQTT Bridge example
 * \author
 *       Tuan PM <tuanpm@live.com>
#include <SoftwareSerial.h>
#include <espduino.h>
#include <mqtt.h>
SoftwareSerial debugPort(2, 3); // RX, TX
ESP esp(&Serial, &debugPort, 4);
MQTT mqtt(&esp);
boolean wifiConnected = false;
void wifiCb(void* response)
  uint32_t status;
  RESPONSE res(response);
  if(res.getArgc() == 1) {
    res.popArgs((uint8_t*)&status, 4);
    if(status == STATION_GOT_IP) {
      debugPort.println("WIFI CONNECTED");
      mqtt.connect("yourserver.com", 1883, false);
      wifiConnected = true;
      //or mqtt.connect("host", 1883); /*without security ssl*/
      mqtt.disconnect();
void mqttConnected(void* response)
  debugPort.println("Connected");
  mqtt.subscribe("/topic/0"); //or mqtt.subscribe("topic"); /*with qos = 0*/
  mqtt.subscribe("/topic/1");
  mqtt.subscribe("/topic/2");
  mqtt.publish("/topic/0", "data0");
void mqttDisconnected(void* response)
void mqttData(void* response)
  debugPort.print("Received: topic=");
  String topic = res.popString();
  debugPort.println(topic);
  debugPort.print("data=");
  String data = res.popString();
  debugPort.println(data);
void mqttPublished(void* response)
  Serial.begin(19200);
  debugPort.begin(19200);
  esp.enable();
  esp.reset();
  while(!esp.ready());
  debugPort.println("ARDUINO: setup mqtt client");
  if(!mqtt.begin("DVES_duino", "admin", "Isb_C4OGD4c3", 120, 1)) {
    debugPort.println("ARDUINO: fail to setup mqtt");
    while(1);
  debugPort.println("ARDUINO: setup mqtt lwt");
  mqtt.lwt("/lwt", "offline", 0, 0); //or mqtt.lwt("/lwt", "offline");
/*setup mqtt events */
  mqtt.connectedCb.attach(&mqttConnected);
  mqtt.disconnectedCb.attach(&mqttDisconnected);
  mqtt.publishedCb.attach(&mqttPublished);
  mqtt.dataCb.attach(&mqttData);
  /*setup wifi*/
  debugPort.println("ARDUINO: setup wifi");
  esp.wifiCb.attach(&wifiCb);
  esp.wifiConnect("DVES_HOME","wifipassword");
  debugPort.println("ARDUINO: system started");
  esp.process();
  if(wifiConnected) {
have you read espduino/README.md at master · tuanpmt/espduino · GitHub
espduino
WARNING: This project discontinue support,
if you want to play ESP8266 with arduino, please visit: Arduino for ESP8266
Compiles fine for me. Please do this:
  • Sketch > Compile/Verify
  • After the compilation fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • Paste the errors in a reply here using code tags (as you have done with the sketch).
