Hallo,
weiß jemand warum auf der allseits bekannten fips admin Seite die falsche IDE Version gezeigt wird? Das sollte bei mir eigentlich 2.3.2 (IDE) sein.
In der vorletzten Zeile wird das mittels ARDUINO abgefragt.
void handleonce() {
if (server.arg(0) != "") {
WiFi.setHostname(server.arg(0).c_str());
File file = LittleFS.open("/config.json", FILE_WRITE);
file.printf("[\"%s\"]", WiFi.getHostname());
file.close();
String fname = String(__FILE__).substring( 3, String(__FILE__).lastIndexOf ('\\'));
String temp = R"({"File":")" + fname.substring(fname.lastIndexOf ('\\') + 1, fname.length()) + R"(", "Build":")" + (String)__DATE__ + " " + (String)__TIME__ +
R"(", "SketchSize":")" + formatBytes(ESP.getSketchSize()) + R"(", "SketchSpace":")" + formatBytes(ESP.getFreeSketchSpace()) +
R"(", "LocalIP":")" + WiFi.localIP().toString() + R"(", "Hostname":")" + WiFi.getHostname() + R"(", "SSID":")" + WiFi.SSID() +
R"(", "GatewayIP":")" + WiFi.gatewayIP().toString() + R"(", "Channel":")" + WiFi.channel() + R"(", "MacAddress":")" + WiFi.macAddress() +
R"(", "SubnetMask":")" + WiFi.subnetMask().toString() + R"(", "BSSID":")" + WiFi.BSSIDstr() + R"(", "ClientIP":")" + server.client().remoteIP().toString() +
R"(", "DnsIP":")" + WiFi.dnsIP().toString() + R"(", "ChipModel":")" + ESP.getChipModel() + R"(", "Reset1":")" + resetReason[rtc_get_reset_reason(0)] +
R"(", "Reset2":")" + resetReason[rtc_get_reset_reason(1)] + R"(", "CpuFreqMHz":")" + ESP.getCpuFreqMHz() + R"(", "HeapSize":")" + formatBytes(ESP.getHeapSize()) +
R"(", "FreeHeap":")" + formatBytes(ESP.getFreeHeap()) + R"(", "MinFreeHeap":")" + formatBytes(ESP.getMinFreeHeap()) +
R"(", "ChipSize":")" + formatBytes(ESP.getFlashChipSize()) + R"(", "ChipSpeed":")" + ESP.getFlashChipSpeed() / 1000000 +
R"(", "ChipMode":")" + flashChipMode[ESP.getFlashChipMode()] + R"(", "IdeVersion":")" + ARDUINO + R"(", "SdkVersion":")" + ESP.getSdkVersion() + R"("})";
server.send(200, "application/json", temp); // Json als Objekt
