ESP für POV (Persistence of Vision)
Hab den folgenden Sketch von hier im Uno zu laufen - funktioniert super:
int delayTime = 1;
int charBreak = 2.1;
int LED1 = 0;
int LED2 = 2;
int LED3 = 12;
int LED4 = 13;
int LED5 = 14;
void setup(){
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
pinMode(LED4, OUTPUT);
pinMode(LED5, OUTPUT);
int a[] = {1, 6, 26, 6, 1};
int b[] = {31, 21, 21, 10, 0};
int c2[] = {14, 17, 17, 10, 0};
int d[] = {31, 17, 17, 14, 0};
int e[] = {31, 21, 21, 17, 0};
int f[] = {31, 20, 20, 16, 0};
int g[] = {14, 17, 19, 10, 0};
int h[] = {31, 4, 4, 4, 31};
int i[] = {0, 17, 31, 17, 0};
int j[] = {0, 17, 30, 16, 0};
int k[] = {31, 4, 10, 17, 0};
int l[] = {31, 1, 1, 1, 0};
int m[] = {31, 12, 3, 12, 31};
int n[] = {31, 12, 3, 31, 0};
int o[] = {14, 17, 17, 14, 0};
int p[] = {31, 20, 20, 8, 0};
int q[] = {14, 17, 19, 14, 2};
int r[] = {31, 20, 22, 9, 0};
int s[] = {8, 21, 21, 2, 0};
int t[] = {16, 16, 31, 16, 16};
int u[] = {30, 1, 1, 30, 0};
int v[] = {24, 6, 1, 6, 24};
int w[] = {28, 3, 12, 3, 28};
int x[] = {17, 10, 4, 10, 17};
int y[] = {17, 10, 4, 8, 16};
int z[] = {19, 21, 21, 25, 0};
int eos[] = {0, 1, 0, 0, 0};
int excl[] = {0, 29, 0, 0, 0};
int ques[] = {8, 19, 20, 8, 0};
void displayLine(int line){
int myline;
myline = line;
if (myline>=16) {digitalWrite(LED1, HIGH); myline-=16;} else {digitalWrite(LED1, LOW);}
if (myline>=8)  {digitalWrite(LED2, HIGH); myline-=8;}  else {digitalWrite(LED2, LOW);}
if (myline>=4)  {digitalWrite(LED3, HIGH); myline-=4;}  else {digitalWrite(LED3, LOW);}
if (myline>=2)  {digitalWrite(LED4, HIGH); myline-=2;}  else {digitalWrite(LED4, LOW);}
if (myline>=1)  {digitalWrite(LED5, HIGH); myline-=1;}  else {digitalWrite(LED5, LOW);}
void displayChar(char c){
if (c == 'a'){for (int i = 0; i <5; i++){displayLine(a[i]);delay(delayTime);}displayLine(0);}
if (c == 'b'){for (int i = 0; i <5; i++){displayLine(b[i]);delay(delayTime);}displayLine(0);}
if (c == 'c2'){for (int i = 0; i <5; i++){displayLine(c2[i]);delay(delayTime);}displayLine(0);}
if (c == 'd'){for (int i = 0; i <5; i++){displayLine(d[i]);delay(delayTime);}displayLine(0);}
if (c == 'e'){for (int i = 0; i <5; i++){displayLine(e[i]);delay(delayTime);}displayLine(0);}
if (c == 'f'){for (int i = 0; i <5; i++){displayLine(f[i]);delay(delayTime);}displayLine(0);}
if (c == 'g'){for (int i = 0; i <5; i++){displayLine(g[i]);delay(delayTime);}displayLine(0);}
if (c == 'h'){for (int i = 0; i <5; i++){displayLine(h[i]);delay(delayTime);}displayLine(0);}
if (c == 'i'){for (int it = 0; it <5; it++){displayLine(i[it]);delay(delayTime);}displayLine(0);}
if (c == 'j'){for (int i = 0; i <5; i++){displayLine(j[i]);delay(delayTime);}displayLine(0);}
if (c == 'k'){for (int i = 0; i <5; i++){displayLine(k[i]);delay(delayTime);}displayLine(0);}
if (c == 'l'){for (int i = 0; i <5; i++){displayLine(l[i]);delay(delayTime);}displayLine(0);}
if (c == 'm'){for (int i = 0; i <5; i++){displayLine(m[i]);delay(delayTime);}displayLine(0);}
if (c == 'n'){for (int i = 0; i <5; i++){displayLine(n[i]);delay(delayTime);}displayLine(0);}
if (c == 'o'){for (int i = 0; i <5; i++){displayLine(o[i]);delay(delayTime);}displayLine(0);}
if (c == 'p'){for (int i = 0; i <5; i++){displayLine(p[i]);delay(delayTime);}displayLine(0);}
if (c == 'q'){for (int i = 0; i <5; i++){displayLine(q[i]);delay(delayTime);}displayLine(0);}
if (c == 'r'){for (int i = 0; i <5; i++){displayLine(r[i]);delay(delayTime);}displayLine(0);}
if (c == 's'){for (int i = 0; i <5; i++){displayLine(s[i]);delay(delayTime);}displayLine(0);}
if (c == 't'){for (int i = 0; i <5; i++){displayLine(t[i]);delay(delayTime);}displayLine(0);}
if (c == 'u'){for (int i = 0; i <5; i++){displayLine(u[i]);delay(delayTime);}displayLine(0);}
if (c == 'v'){for (int i = 0; i <5; i++){displayLine(v[i]);delay(delayTime);}displayLine(0);}
if (c == 'w'){for (int i = 0; i <5; i++){displayLine(w[i]);delay(delayTime);}displayLine(0);}
if (c == 'x'){for (int i = 0; i <5; i++){displayLine(x[i]);delay(delayTime);}displayLine(0);}
if (c == 'y'){for (int i = 0; i <5; i++){displayLine(y[i]);delay(delayTime);}displayLine(0);}
if (c == 'z'){for (int i = 0; i <5; i++){displayLine(z[i]);delay(delayTime);}displayLine(0);}
if (c == '!'){for (int i = 0; i <5; i++){displayLine(excl[i]);delay(delayTime);}displayLine(0);}
if (c == '?'){for (int i = 0; i <5; i++){displayLine(ques[i]);delay(delayTime);}displayLine(0);}
if (c == '.'){for (int i = 0; i <5; i++){displayLine(eos[i]);delay(delayTime);}displayLine(0);}
delay(charBreak);
void displayString(char* s){
for (int i = 0; i<=strlen(s); i++){
displayChar(s[i]);
void loop(){
displayString("hallo . ");
Will ich ihn in den ESP-201 laden bekomm ich folgende Mecker:
Build-Optionen wurden verändert, alles wird neu gebaut
POV5LED2.ino:61:10: warning: multi-character character constant [-Wmultichar]
POV5LED2.ino: In function 'void loop()':
POV5LED2.ino:98:25: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\CarstenTower\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//lib\liblwip.a(dhcpserver.o):(.bss+0x10): multiple definition of `s'
POV5LED2.cpp.o:(.data+0xc8): first defined here
c:/users/carstentower/appdata/roaming/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: Warning: size of symbol `s' changed from 20 in POV5LED2.cpp.o to 2 in C:\Users\CarstenTower\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0/tools/sdk//lib\liblwip.a(dhcpserver.o)
collect2.exe: error: ld returned 1 exit status
Fehler beim Kompilieren.
Ich weiß nicht was die von mir wollen... help! :o
zu deutsch: mehrfach Definierung von s.
char* s
int s[]
Könnte das sein.
Naja, der gleiche Sketch läuft ja im UNO problemlos...
Nur wenn ich für den ESP kompiliere wird gemeckert. :o
Also das "s" ist erst mal Schuld! :grin: Böses "s"!
Hab mal geändert: s zu s2 (liebes s)
int s2[] = {8, 21, 21, 2, 0};
if (c == 's2'){for (int i = 0; i <5; i++){displayLine(s2*);delay(delayTime);}displayLine(0);}*
Dann will das Zeugs auch in den ESP und funzt sogar.
*int delayTime = 1;
int LED1 = 0;
int LED2 = 2;
int LED3 = 12;
int LED4 = 13;
int LED5 = 14;
void setup(){
int myline;
myline = line;
if (c == 's2'){for (int i = 0; i <5; i++){displayLine(s2[i]);delay(delayTime);}displayLine(0);}
delay(charBreak);
displayChar(s[i]);
void loop(){
displayString("hallo");
Was ich nicht verstehe: Beim UNO hat nix gemeckert zwecks "mehrfach Definierung" !! Hab ich einen multitoleranten UNO und ein kleines ESP-Sensibelchen erwischt? Da raucht stoni die Birne...
Abgesehen davon, hast du da noch zwei Warnungen drin
ein char ist ein Zeichen. C kann chars zwar zu int befördern, aber er bringt dir da zu recht eine Warnung wenn du Dinge wie 'c2' oder 's2' schreibst. Das ist einfach nicht sauber.
Und String Literale sind const! Also so:
void displayString(const char* s)
Dann geht auch die andere Warnung weg
Danke, da hat der kleine Chinese also unsauber programmiert.... tssss, tssss, tssss :grin:
Warnung bleibt aber auch mit const char* s:
POV5LED4.ino:61:10: warning: multi-character character constant [-Wmultichar]
POV5LED4.ino:77:10: warning: multi-character character constant [-Wmultichar]
Die Warnung ist ja auch wegen was anderem
if (c == 'c2')
if (c == 's2')
Ein Zeichen! Nicht zwei
c soll sich nicht so kleinlich haben... :grin: ob nun ein oder zwei Zeichen... :grin:
Na da muß stoni nochmal etwas grübeln wie man das besser machen kann. :-[
evtl. ist "c2" in chinesisch ja auch ein Zeichen... :grin:
if (c == 'c')
if (c == 's')
Was ist denn daran so kompliziert?
Du fragst auf das Zeichen ab dass im String steht. Wie das Array dazu heißt ist da vollkommen irrelevant. Da kann ruhig völlig anders heißen, wie du bei den Satzzeichen siehst.
Ne, will er nicht:
POV5LED4.ino: In function 'void displayChar(char)':
POV5LED4:61: error: invalid types 'char[int]' for array subscript
Ah, habs endlich kapiert:
belassen
und
if (c == 'c2') als if (c == 'c')
if (c == 's2') als if (c == 's')
Naja, manchmal dauert's bei mir etwas... :grin:
int delayTime = 1;
int LED1 = 0;
int LED2 = 2;
int LED3 = 12;
int LED4 = 13;
int LED5 = 14;
void setup(){
int myline;
myline = line;
if (c == 'c'){for (int i = 0; i <5; i++){displayLine(c2[i]);delay(delayTime);}displayLine(0);}
if (c == 's'){for (int i = 0; i <5; i++){displayLine(s2[i]);delay(delayTime);}displayLine(0);}
delay(charBreak);
void displayString(const char* s){
displayChar(s[i]);
void loop(){
