I'm trying to upload distance data to thingspeak web platform. Have a look this video.(highly recommend to watch it)
As you can see through video, I can only update FW (forward) Field 1 chart, other 4 fields remain same.
Could you analyze my code and tell me where is the part I coded wrong or which idea I'm trying to imply to arduino is totally logical fault !
BW sensor is damaged and it's sensing nothing (0,null) instead of right value. Do not mind it.
I tried to build up for loop to receive data from 4 sensor then send it to 4 field but didn't succeed in it.So I made each sensor get it's own value and send it to thingspeak separately .
It may seem too long, however I'm repeating same things again and again for 4 sensors after each comment statement // TCP connection FW
Here is the my code:
#include <SoftwareSerial.h>
#include <stdlib.h>
int ledPin = 13;
String apiKey = "2TNSKZAUY0FUD7QY";
SoftwareSerial ser(2,3); // RX, TX
pinMode(ledPin, OUTPUT);
ser.begin(9600);
pinMode(11,OUTPUT); //Trigger FW
pinMode(10,INPUT); //Echo
pinMode(5,OUTPUT); //Trigger R
pinMode(4,INPUT); //Echo
pinMode(A1,OUTPUT); //Trigger L
pinMode(A0,INPUT); //Echo
pinMode(A2,OUTPUT); //Trigger BW
pinMode(A3,INPUT); //Echo
// reset ESP8266
ser.println("AT+RST");
long duration1, distance1;
long duration2, distance2;
long duration3, distance3;
long duration4, distance4;
digitalWrite(ledPin, HIGH);
delay(200);
digitalWrite(ledPin, LOW);
// FW 1 pin distance calculation
digitalWrite(11,LOW);
delayMicroseconds(2);
digitalWrite(11,HIGH);
delayMicroseconds(10);
duration1 = pulseIn(10,HIGH);
distance1 = (duration1/2)/29.1;
Serial.print(distance1);
Serial.println("cm//");
// R 2 pin distance calculation
digitalWrite(5,LOW);
digitalWrite(5,HIGH);
duration2 = pulseIn(4,HIGH);
distance2 = (duration2/2)/29.1;
Serial.print(distance2);
// L 3 pin distance calculation
digitalWrite(A5,LOW);
digitalWrite(A5,HIGH);
duration3 = pulseIn(A0,HIGH);
distance3 = (duration3/2)/29.1;
Serial.print(distance3);
// BW 4 pin distance calculation
digitalWrite(A2,LOW);
digitalWrite(A2,HIGH);
duration4 = pulseIn(A3,HIGH);
distance4 = (duration4/2)/29.1;
Serial.print(distance4);
Serial.println("distanceFW");
Serial.println(distance1);
Serial.println("distanceR");
Serial.println(distance2);
Serial.println("distanceL");
Serial.println(distance3);
Serial.println("distanceBW");
Serial.println(distance4);
String cmd1 = "AT+CIPSTART=\"TCP\",\"";
cmd1 += "184.106.153.149"; // api.thingspeak.com
cmd1 += "\",80";
ser.println(cmd1);
if(ser.find("Error")){
Serial.println("AT+CIPSTART error");
return;
// FW prepare GET string
String getStr1 = "GET /update?api_key=";
getStr1 += apiKey;
getStr1 +="&field1=";
getStr1 += String(distance1);
getStr1 += "\r\n\r\n";
// send data length FW
cmd1 = "AT+CIPSEND=";
cmd1 += String(getStr1.length());
ser.println(cmd1);
if(ser.find(">")){
ser.print(getStr1);
else{
ser.println("AT+CIPCLOSE1");
// alert user
Serial.println("AT+CIPCLOSE1");
// TCP connection R
String cmd2 = "AT+CIPSTART=\"TCP\",\"";
cmd2 += "184.106.153.149"; // api.thingspeak.com
cmd2 += "\",80";
ser.println(cmd2);
return;
// R prepare GET string
String getStr2 = "GET /update?api_key=";
getStr2 += apiKey;
getStr2 +="&field2=";
getStr2 += String(distance2);
getStr2 += "\r\n\r\n";
// R send data length
cmd2 = "AT+CIPSEND=";
cmd2 += String(getStr2.length());
ser.println(cmd2);
if(ser.find(">")){
ser.print(getStr2);
else{
ser.println("AT+CIPCLOSE2");
// alert user
Serial.println("AT+CIPCLOSE2");
// TCP connection L
String cmd3 = "AT+CIPSTART=\"TCP\",\"";
cmd3 += "184.106.153.149"; // api.thingspeak.com
cmd3 += "\",80";
ser.println(cmd3);
return;
// L prepare GET string
String getStr3 = "GET /update?api_key=";
getStr3 += apiKey;
getStr3 +="&field3=";
getStr3 += String(distance3);
getStr3 += "\r\n\r\n";
// L send data length
cmd3 = "AT+CIPSEND=";
cmd3 += String(getStr3.length());
ser.println(cmd3);
if(ser.find(">")){
ser.print(getStr3);
else{
ser.println("AT+CIPCLOSE3");
// alert user
Serial.println("AT+CIPCLOSE3");
// TCP connection BW
String cmd4 = "AT+CIPSTART=\"TCP\",\"";
cmd4 += "184.106.153.149"; // api.thingspeak.com
cmd4 += "\",80";
ser.println(cmd4);
return;
// BW prepare GET string
String getStr4 = "GET /update?api_key=";
getStr4 += apiKey;
getStr4 +="&field4=";
getStr4 += String(distance4);
getStr4 += "\r\n\r\n";
// BW send data length
cmd4 = "AT+CIPSEND=";
cmd4 += String(getStr4.length());
ser.println(cmd4);
if(ser.find(">")){
ser.print(getStr4);
else{
ser.println("AT+CIPCLOSE4");
// alert user
Serial.println("AT+CIPCLOSE4");
// thingspeak needs 15 sec delay between updates
delay(8000);
thanks for your interest
