ESP_NOW char values
hello, the esp now code worked with int type values in the simple structure
typedef struct struct_message {
  int id;
  char letter[3];
} struct_message;
struct_message espDataA;
strcpy(espDataA.letter, "A");
espDataA.id = BOARD_ID;
but it doesn't work with chars. i just want to send and A but strcpy doesn't work and how many bytes i should put int brackets [32] if i only have "A"?
also should i change something in send and receive code ?
        esp_now_send(broadcastAddress, (uint8_t *) &espDataD, sizeof(espDataD));
  memcpy(&espData, incomingData, sizeof(espData));
espDataA.letter [0] = 'A';
espDataA.letter [1] = '\0';
:wink:
better but stil something is wrong
esp_transmitter:29:1: error: 'espDataD' does not name a type
   29 | espDataD.id = BOARD_ID;
esp_transmitter:22:1: error: 'espDataA' does not name a type
   22 | espDataA.letter [0] = 'A';
  int id;
  char letter[3];
} struct_message;
struct_message espDataB;
struct_message espDataC;
struct_message espDataD;
espDataB.letter [0] = 'B';
espDataC.letter [0] = 'C';
espDataD.letter [0] = 'D';
espDataB.id = BOARD_ID;
espDataC.id = BOARD_ID;
Hello
Why not simply char letter; then espDataA.letter = 'A';
and if i only have a on letter [] should i define as char letter[1]? your \0 just fill up the empty space ?on receiver reading will that matter ?
will know to write id at id and letter [0] from transmitter at letter [0] on the receiver
memcpy(&myData, incomingData, sizeof(myData));
Use exactly the same struct on both sides
  int id;
  char letter;
it also has struct_message at the end before the coma and typedef idkn why
  int id;
  char letter;
} struct_message;
Can we have the question in terms that may make some sense, please?
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "NodeMCU 0.9 (ESP-12 Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
   22 | espDataA.letter = 'A';
esp_transmitter:23:1: error: 'espDataB' does not name a type
   23 | espDataB.letter = 'B';
esp_transmitter:24:1: error: 'espDataC' does not name a type
   24 | espDataC.letter = 'C';
esp_transmitter:25:1: error: 'espDataD' does not name a type
   25 | espDataD.letter = 'D';
esp_transmitter:26:1: error: 'espDataA' does not name a type
   26 | espDataA.id = BOARD_ID;
esp_transmitter:27:1: error: 'espDataB' does not name a type
   27 | espDataB.id = BOARD_ID;
esp_transmitter:28:1: error: 'espDataC' does not name a type
   28 | espDataC.id = BOARD_ID;
exit status 1
option enabled in File -> Preferences.
i just saw that i set those values outside the setup or loop and if i move them in setup it compiles
"Called" what?
set values to that struct_message
can watchdog trigger if i have to many things to do in the setup ?
it is time you posted the whole code
 * TRANSMITTER
//libraries
#include <ESP8266WiFi.h>
#include <espnow.h>
//esp8266 transmitter object
uint8_t broadcastAddress[] = {0xCC, 0x50, 0xE3, 0x3C, 0xA8, 0x4B}; //adress for master receiver
#define BOARD_ID 1
//esp data to send
  int id;
  char letter;
} struct_message;
//button variables
const int buttonA = 2;
const int buttonB = 3;
const int buttonC = 4;
const int buttonD = 5;
int buttonStateA = HIGH;
int lastButtonStateA = HIGH;
int buttonStateB = HIGH;
int lastButtonStateB = HIGH;
int buttonStateC = HIGH;
int lastButtonStateC = HIGH;
int buttonStateD = HIGH;
int lastButtonStateD = HIGH;
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 50;
//esp send data function
void OnDataSent(uint8_t *mac_addr, uint8_t sendStatus) {
  if (sendStatus == 0) {
    Serial.println("Delivery success");
  else {
    Serial.println("Delivery fail");
  //radio temporary
  //buttons initialization
  pinMode(buttonA, INPUT_PULLUP);
  pinMode(buttonB, INPUT_PULLUP);
  pinMode(buttonC, INPUT_PULLUP);
  pinMode(buttonD, INPUT_PULLUP);
  //data to send
  //esp initialization
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  if (esp_now_init() != 0) {
    Serial.println("Error initializing ESP-NOW");
    return;
  esp_now_set_self_role(ESP_NOW_ROLE_CONTROLLER);
  esp_now_register_send_cb(OnDataSent);
  esp_now_add_peer(broadcastAddress, ESP_NOW_ROLE_SLAVE, 1, NULL, 0);
  ESP.wdtDisable();
  //reset watchdog
  ESP.wdtFeed();
  //get buttons values
  int readingA = digitalRead(buttonA);
  int readingB = digitalRead(buttonB);
  int readingC = digitalRead(buttonC);
  int readingD = digitalRead(buttonD);
  //debounce
  if ((readingA != lastButtonStateA) || (readingB != lastButtonStateB) || (readingC != lastButtonStateC) || (readingD != lastButtonStateD)) {
    lastDebounceTime = millis();
  //execute if button pressed
  if ((millis() - lastDebounceTime) > debounceDelay) {
    if (readingA != buttonStateA) {
      buttonStateA = readingA;
      if (buttonStateA == LOW) {
        esp_now_send(broadcastAddress, (uint8_t *) &espDataA, sizeof(espDataA));
    } else if (readingB != buttonStateB) {
      buttonStateB = readingB;
      if (buttonStateB == LOW) {
        esp_now_send(broadcastAddress, (uint8_t *) &espDataB, sizeof(espDataB));
    } else if (readingC != buttonStateC) {
      buttonStateC = readingC;
      if (buttonStateC == LOW) {
        esp_now_send(broadcastAddress, (uint8_t *) &espDataC, sizeof(espDataC));
    } else if (readingD != buttonStateD) {
      buttonStateD = readingD;
      if (buttonStateD == LOW) {
  //update button state
  lastButtonStateA = readingA;
  lastButtonStateB = readingB;
  lastButtonStateC = readingC;
  lastButtonStateD = readingD;
what happens if you change
to
  int id;
  char letter;
still compiles on verify
Still? so what was the problem before if it compiled as well?
