that IS what the broadcast-mac-adress is doing. ALL and EVERY ESP that is setup to listen on the SAME WiFi-Channel will receive the messages send with broadcast-adress
You can set the WiFi-channel with the command
wifi_set_channel("channelOfYourChoice");
If a specified MAC-adress different from 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF does not match the receivers MAC-adress the send will fail and nothing will be received.
If you setup any ESP8266 with the same configuration of
using the same WiFi-channel and using the boradcast-adress {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}
as "adress" of the receiver
uint8_t broadcastAddress[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
wifi_set_channel(ChannelOfYourChoice);
esp_now_send(broadcastAddress,......
all ESP8266 will receive this message
The broadcast-adress must have a number to make the ESP8266 recognise
If the adress is {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF} DON'T compare with your own adress receive the message and process the message
do you get it?
If not flash three ESP8266 with the exact same code all using
and test it
best regards Stefan
