Esp sending to InfluxDb and Thingspeak
Hello.
How to send data to two clients? I would like to add sending to Thingspeak to the sketch of the InfluxDB example.
Below is a sketch of InfluxDB2 support.
If I add Thinkspeak the compiler informs me that one client has already been declared and an error occurs.
 * Basic Write Example code for InfluxDBClient library for Arduino
 * Data can be immediately seen in a InfluxDB UI: wifi_status measurement
 * Enter WiFi and InfluxDB parameters below
 * Measures signal level of the actually connected WiFi network
 * This example supports only InfluxDB running from unsecure (http://...)
 * For secure (https://...) or Influx Cloud 2 use SecureWrite example
#if defined(ESP32)
#include <WiFiMulti.h>
WiFiMulti wifiMulti;
#define DEVICE "ESP32"
#elif defined(ESP8266)
#include <ESP8266WiFiMulti.h>
ESP8266WiFiMulti wifiMulti;
#define DEVICE "ESP8266"
#endif
#include <InfluxDbClient.h>
// WiFi AP SSID
#define WIFI_SSID "ssid"
// WiFi password
#define WIFI_PASSWORD "password"
// InfluxDB  server url. Don't use localhost, always server name or ip address.
// E.g. http://192.168.1.48:8086 (In InfluxDB 2 UI -> Load Data -> Client Libraries),
#define INFLUXDB_URL "influxdb-url"
// InfluxDB 2 server or cloud API authentication token (Use: InfluxDB UI -> Load Data -> Tokens -> <select token>)
#define INFLUXDB_TOKEN "toked-id"
// InfluxDB 2 organization id (Use: InfluxDB UI -> Settings -> Profile -> <name under tile> )
#define INFLUXDB_ORG "org"
// InfluxDB 2 bucket name (Use: InfluxDB UI -> Load Data -> Buckets)
#define INFLUXDB_BUCKET "bucket"
// InfluxDB v1 database name
//#define INFLUXDB_DB_NAME "database"
// InfluxDB client instance
InfluxDBClient client(INFLUXDB_URL, INFLUXDB_ORG, INFLUXDB_BUCKET, INFLUXDB_TOKEN);
// InfluxDB client instance for InfluxDB 1
//InfluxDBClient client(INFLUXDB_URL, INFLUXDB_DB_NAME);
// Data point
Point sensor("wifi_status");
  // Connect WiFi
  Serial.println("Connecting to WiFi");
  WiFi.mode(WIFI_STA);
  wifiMulti.addAP(WIFI_SSID, WIFI_PASSWORD);
  while (wifiMulti.run() != WL_CONNECTED) {
    Serial.print(".");
  // Set InfluxDB 1 authentication params
  //client.setConnectionParamsV1(INFLUXDB_URL, INFLUXDB_DB_NAME, INFLUXDB_USER, INFLUXDB_PASSWORD);
  // Add constant tags - only once
  sensor.addTag("device", DEVICE);
  sensor.addTag("SSID", WiFi.SSID());
  // Check server connection
  if (client.validateConnection()) {
    Serial.print("Connected to InfluxDB: ");
    Serial.println(client.getServerUrl());
    Serial.print("InfluxDB connection failed: ");
    Serial.println(client.getLastErrorMessage());
  // Store measured value into point
  sensor.clearFields();
  // Report RSSI of currently connected network
  sensor.addField("rssi", WiFi.RSSI());
  // Print what are we exactly writing
  Serial.print("Writing: ");
  Serial.println(client.pointToLineProtocol(sensor));
  // If no Wifi signal, try to reconnect it
  if (wifiMulti.run() != WL_CONNECTED) {
    Serial.println("Wifi connection lost");
  // Write point
  if (!client.writePoint(sensor)) {
    Serial.print("InfluxDB write failed: ");
  //Wait 10s
  Serial.println("Wait 10s");
  delay(10000);
In the Thingspeak library, client and sending are declared like this:
WiFiClient  client;
ThingSpeak.begin(client);
I
