Esp_sleep_enable_timer_wakeup
Hello everyone!
This is my first time posting here and sorry if i do not post in the correct category . I want to ask you if there is any possibility to change
#define TIME_TO_SLEEP 5;
to
#define TIME_TO_SLEEP yourInputString = readFile(SPIFFS, "/inputString.txt");
In the "/inputString.txt" is a number like 30 . I want to be able to put that number in the TIME_TO_SLEEP if there is a possibility .
server.on("/L", HTTP_GET, []
(AsyncWebServerRequest *request) {
digitalWrite(led_gpio, LOW);                // GET /L turns the LED off
    esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP);
    esp_deep_sleep_start();
request->send(200, "text/plain", "ok");
I tried putting
and i get this error
 'yourInputString' was not declared in this scope
I am using SPIFFS to write and read the file inputString.txt
I am a beginner in programming so be kind with me please . Thank you in advanced !
Canned message to you that may help you help us.
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Please post a schematic.
Please post an image of your project.
Please describe the problem better then you just did.
You want to use a variable not a define
String yourInputString = readFile(SPIFFS, "/inputString.txt");
As a note SPIFF's have been depreciated on the ESP's. Use preference's of littleFS.
Here is my sketch :
#include "WiFi.h"
#include "ESPAsyncWebServer.h"
#include "SPIFFS.h"
#include "FS.h"
const char* ssid = "myssid";
const char* password =  "mypass";
const byte led_gpio = 22;
AsyncWebServer server(80);
IPAddress local_IP(192, 168, 0, 8);
IPAddress gateway(192, 168, 0, 1);
IPAddress subnet(255, 255, 255, 0);
const char* PARAM_STRING = "inputString";
const char* PARAM_INT = "inputInt";
const char* PARAM_FLOAT = "inputFloat";
// HTML web page to handle 3 input fields (inputString, inputInt, inputFloat)
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html><head>
  <title>ESP Input Form</title>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <script>
    function submitMessage() {
      alert("Saved value to ESP SPIFFS");
      setTimeout(function(){ document.location.reload(false); }, 500);
  </script></head><body>
  <form action="/get" target="hidden-form">
    inputString (current value %inputString%): <input type="text" name="inputString">
    <input type="submit" value="Submit" onclick="submitMessage()">
  </form><br>
  <iframe style="display:none" name="hidden-form"></iframe>
</body></html>)rawliteral";
void notFound(AsyncWebServerRequest *request) {
  request->send(404, "text/plain", "Not found");
String readFile(fs::FS &fs, const char * path) {
  Serial.printf("Reading file: %s\r\n", path);
  File file = fs.open(path, "r");
  if (!file || file.isDirectory()) {
    Serial.println("- empty file or failed to open file");
    return String();
  Serial.println("- read from file:");
  String fileContent;
  while (file.available()) {
    // fileContent+=String((char)file.read());
    for (int i = 1; i <= 10; i++) {
      String line = file.readStringUntil('n');
      Serial.println(line);
  file.close();
  Serial.println(fileContent);
  return fileContent;
void writeFile(fs::FS &fs, const char * path, const char * message) {
  Serial.printf("Writing file: %s\r\n", path);
  File file = fs.open(path, "w");
  if (!file) {
    Serial.println("- failed to open file for writing");
    return;
  if (file.print(message)) {
    Serial.println("- file written");
    Serial.println("- write failed");
  file.close();
// Replaces placeholder with stored values
String processor(const String& var) {
  //Serial.println(var);
  if (var == "inputString") {
    return readFile(SPIFFS, "/inputString.txt");
  else if (var == "inputInt") {
    return readFile(SPIFFS, "/inputInt.txt");
  else if (var == "inputFloat") {
    return readFile(SPIFFS, "/inputFloat.txt");
  return String();
  SPIFFS.begin();
  pinMode(led_gpio, OUTPUT);
  digitalWrite(led_gpio, HIGH);
  // Initialize SPIFFS
#ifdef ESP32
  if (!SPIFFS.begin(true)) {
    Serial.println("An Error has occurred while mounting SPIFFS");
    return;
#else
  if (!SPIFFS.begin()) {
    return;
#endif
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  if (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println("WiFi Failed!");
    return;
  Serial.print("IP Address: ");
  // Send web page with input fields to client
  server.on("/", HTTP_GET, [](AsyncWebServerRequest * request) {
    request->send_P(200, "text/html", index_html, processor);
  // Send a GET request to <ESP_IP>/get?inputString=<inputMessage>
  server.on("/get", HTTP_GET, [] (AsyncWebServerRequest * request) {
    String inputMessage;
    // GET inputString value on <ESP_IP>/get?inputString=<inputMessage>
    if (request->hasParam(PARAM_STRING)) {
      inputMessage = request->getParam(PARAM_STRING)->value();
      writeFile(SPIFFS, "/inputString.txt", inputMessage.c_str());
    // GET inputInt value on <ESP_IP>/get?inputInt=<inputMessage>
    else if (request->hasParam(PARAM_INT)) {
      inputMessage = request->getParam(PARAM_INT)->value();
      writeFile(SPIFFS, "/inputInt.txt", inputMessage.c_str());
    // GET inputFloat value on <ESP_IP>/get?inputFloat=<inputMessage>
    else if (request->hasParam(PARAM_FLOAT)) {
      inputMessage = request->getParam(PARAM_FLOAT)->value();
      writeFile(SPIFFS, "/inputFloat.txt", inputMessage.c_str());
    else {
      inputMessage = "No message sent";
    Serial.println(inputMessage);
    request->send(200, "text/text", inputMessage);
  // Receive an HTTP GET request
  server.on("/H", HTTP_GET, [] (AsyncWebServerRequest * request) {
    digitalWrite(led_gpio, HIGH);               // GET /H turns the LED on
  server.on("/L", HTTP_GET, [] (AsyncWebServerRequest * request) {
  server.on("/O", HTTP_GET, [] (AsyncWebServerRequest * request) {
    digitalWrite(led_gpio, HIGH);                // GET /L turns the LED off
  server.onNotFound(notFound);
  server.begin();
  // To access your stored values on inputString, inputInt, inputFloat
  Serial.print("*** Your inputString: ");
  Serial.println(yourInputString);
  //int yourInputInt = readFile(SPIFFS, "/inputInt.txt").toInt();
  // Serial.print("*** Your inputInt: ");
  // Serial.println(yourInputInt);
  // float yourInputFloat = readFile(SPIFFS, "/inputFloat.txt").toFloat();
  // Serial.print("*** Your inputFloat: ");
  // Serial.println(yourInputFloat);
  delay(5000);
And my error is :
Arduino: 1.8.19 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
C:\Users\Zet\AppData\Local\Temp\arduino_modified_sketch_284202\sketch_nov04a.ino: In lambda function:
sketch_nov04a:11:23: error: 'yourInputString' was not declared in this scope
C:\Users\Zet\AppData\Local\Temp\arduino_modified_sketch_284202\sketch_nov04a.ino:171:35: note: in expansion of macro 'TIME_TO_SLEEP'
Multiple libraries were found for "WiFi.h"
 Used: C:\Users\Zet\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
 Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
exit status 1
Thank you!
String yourInputString ="I'm need to be defined before I can be used";
Now its defined.
Follow the link in post#2 about to learn about variables.
i get this error
sketch_nov04abcde:11:61: error: 'readFile' was not declared in this scope
C:\Users\Zet\Documents\Arduino\sketch_nov04abcde\sketch_nov04abcde.ino: In lambda function:
sketch_nov04abcde:173:48: error: cannot convert 'String' to 'uint64_t {aka long long unsigned int}' for argument '1' to 'esp_err_t esp_sleep_enable_timer_wakeup(uint64_t)'
exit status 1
Thank you !
Is there a function called readfile?
This is it?
    return String();
If i read the file in the serial monitor the output of the text in /inputInt.txt is correct , but when i put in :
esp_sleep_enable_timer_wakeup(readFile(SPIFFS, "/inputInt.txt").toInt());
it returns 0
